ASUS V6J-X009P Notebook Logo
Anonymous Posted on Dec 19, 2009
Asus V6J reset cmos button please
Asus V6J
I need to know the button combination that will either restore the default bios, or give me a forced usb/cd boot control, as it stands now, lappy shuts down after 5 seconds, no post, no beeps,no visual just fans/light/crash.
Anonymous
Level 3:
  • Master 2,229 Answers
  • Posted on Dec 19, 2009
Anonymous
Master
Level 3:
Answers
2229
Questions
Helped
564101
Points
6804
The computer should show you a key to hit to enter the setup. Nomally the keys may be F2, F10, DEL, or some other key.
If your computer does not even give you any display, then you can't enter setup--it's failing the POST which means it won't work at all.
In a laptop, you could take it apart far enough to find the CMOS battery and disconnect it to reset the CMOS, but I'm thinking you might have a hardware problem here--like maybe a motherboard.
One thing you can do is unplug it, remove the battery, then reinstall the battery, plug it in and try again. In a laptop, anything further will require dissembling the case.
Asus m60j
Removing the CMOS battery for about a minute and putting it back in might help restore BIOS to default settings. I have not done this on a laptop yet, but that is generally how you reset BIOS. You may have to find which 'compartment' on the underside of the laptop to unscrew to remove and reseat the CMOS battery.
tip
Retrieve Password on ASUS Eee Pad Tablet
Looking For a Password Recovery Program to Access Your Locked ASUS Netbook? Apple's iPad 2 maybe the hottest thing on the hip-happenin' trendy tablet block, but Asus isn't that behind with its own version, currently dubbed the Eee Pad. Till April 2011, this computer has occupied a considerable market share. In this article, we will learn how to <a href="http://www.windowspasswordsrecovery.com/retrieve-asus-password.htm">retrieve ASUS EPad Password</a>. <br /> <a href="http://www.windowspasswordsrecovery.com/images/knowledge/retrieve-asus-password/asus-eee-pad-tablet-password-big.jpg"><img src="asus-eee-pad-tablet-password.jpg" /></a> What is ASUS Eee PC? Asus Eee PC is a subnotebook/netbook computer line from ASUSTeK Computer Incorporated, and a part of the Asus Eee product family. At the time of its introduction in late 2007, it was noted for its combination of a light weight, Linux operating system, solid-state drive and relatively low cost. Newer models have added the option of Windows operating system and traditional hard disk drives.<br /> The first Eee PC was a milestone in the personal computer business, launching the netbook category of small, low cost laptops. According to Asus, the name Eee derives from "the three Es," an abbreviation of its advertising slogan for the device: "Easy to learn, Easy to work, Easy to play".<br /> Some of ASUS's hot products <b>Eee Pad</b>: Eee Slate EP121, Eee Pad Transformer TF101<br /> <b>Eee PC</b>: Eee PC T91, Eee PC 1000HD<br /> <b>EeeBox PC</b>: EeeBox PC B201, EeeBox PC EB1502<br /> How to Regain Password on ASUS Eee Pad Tablet? There are 2 passwords in an EPad, a bios password, an Operation System password. We will separately discuss the 2 cases.<br /> Bios Password Bios password is setting on the bios config, we can press Del button during loading the PC to enter bios config menu, then remove the bios password. Sometimes, you don't know the bios password, look this guide: "<a href="http://www.blog.windowspasswordsrecovery.com/top-3-methods-to-crack-bios-password/">Top 3 methods to crack bios password!</a>".<br /> <b>Tips</b>: As we know, EPad uses touch screen. We could connect it with a USB keyboard to press Del button. <br /> Operation System Password We can install many OS on an ASUS tablet, for example: Linux, Unix, MAC OS, Windows. Here we discuss only windows. <b>1.</b> Download <a href="http://www.windowspasswordsrecovery.com/downloads/Windows_Password_Recovery_Tool_Ent_Trial.exe"><b>Windows Password Recovery Tool</b></a> (free trial).<br /> <b>2.</b> Install and run it.<br /> <b>3.</b> Create a password reset disk. A CD/DVD disk, or a USB Flash Disk, depend on the locked ASUS PC's support.<br /> <b>4.</b> Boot the locked ASUS computer from the password reset disk. <br /> Note: You may need to config bios setting to set it boot from the password reset disk. The 2 articles can help you.<br /> a. <a href="http://www.windowspasswordsrecovery.com/getting_started/bios.htm">Boot from the CD/DVD-ROM</a><br /> b. <a href="http://www.windowspasswordsrecovery.com/getting_started/bios_usb.htm">Boot from the USB Flash Drive</a><br /> <b>5.</b> On the password recovery Windows, select the user account that you forget its logon password, click "reset" button.<br /> <b>6.</b> Confirm you action, then that user's password will be removed.<br /> <b>7.</b> Disconnect the password reset disk, and reboot your ASUS computer. You will access Windows OS without password ( blank password ).<br /> Finally Get away from the troubles of forgetting ASUS PC Password, no matter it is bios/cmos password or Windows password. <br /> Tips: <b>1.</b> The Windows Password Recovery Tool supports all versions of Windows OS, including Windows 7, Vista, XP, 2000, 2003, 2008. It is popular way of regain your password, even you don't have a password reset disk. <br /> <b>2.</b> Keep in mind that this tool can be only used on your own computer, never try to use it to crack PC password without permission. Otherwise, you will get into trouble by law.<br /> <b>3.</b> You can <b><a href="http://www.windowspasswordsrecovery.com/create-windows-7-password-reset-disk.htm">create a ASUS Eee Pad Password Reset disk</a></b> before you forget password. <br />
on May 23, 2011 • Computers & Internet
1helpful
ASUS Eee PC 1000HE bios password
REMOVE BIOS PASSWORD
PC BIOS toolkit is a password removal/decrypt and BIOS settings modification/backup/restore.
http://www.syschat.com/download120.html&act=down
CMOSPwd - CMOS password recovery tools
http://majorgeeks.com/CmosPwd_d239.html
Using a computer with Internet access, download the files from these WEB sites and create a bootable CD disc or copy to the USB memory stick to run them.
What keys change bios values on asus u46e
Restart your computer
During the boot process you will see on the screen to press a certain key to enter setup usually the Delete or F2 key
this will vary depending on your computer and operating system
Press and hold that key during the boot up process to enter BIOS using the arrow keys load failsafe defaults or load optimized defaults press escape then press f10 to save to cmos to restart
this will set the boot order
hope this helps
if this fails you might try some of these
Acer: - Ctrl+Alt+Esc
ALR PC: (F2) or (Ctrl)(Alt)Esc)
AMI BIOS: (Del), (F1) or (F2)
AST, Advantage, Award, Tandon: - Ctrl + Alt + Esc
Award BIOS: (Del) or (Ctrl)(Alt)(Esc)
Bios backdoor for asus laptop
BIOS passwords can be reset in two ways:
1. using software 2. using hardware.
I would first try resetting using software, here are two software apps to reset or retrieve BIOS passwords.
!BIOS - is a PC BIOS toolkit offering password removal/decrypt and BIOS settings modification/backup/restore.
You can download it here:
CmosPwd - Cmos password recovery tools
http://www.syschat.com/download121.html&act=down
You will need to create a bootable Dos, or Linux or NT cd in order to run them.
Good Luck!
Please can you tell me how to reset the cmos on a samsung R510 Laptop
Hello you just have to remove the cmos battery:
Press the release pad and the battery will pop out
DO NOT have any power on disconnect all power and usb cables
when you do that.
Wait for 10 min. or so with the battery out
and the bios will reset back to factory settings.
Replace the battery and boot up your machine and enter the bios
you kave to configure the boot order.
Here is some youtube videos how you do that:
http://www.youtube.com/results?search_query=Intel+D945GTP+bios+setting&oq=Intel+D945GTP+bios+setting&gs_l=youtube.12...55167.59517.0.61846.6.6.0.0.0.0.85.411.6.6.0...0.0...1ac.1j2.lSt1MwgqUkQ
But it depends what bios you have.
Good luck
2answers
After replacing on board lithium cell, computer will not boot up. Goes through BIOS ok but no further, even tried replacing hard disk and booting from removable media drives (after setting BIOS...
Did you swap the Cmos jumpers from 1-2 to 2-3 to clear Cmos before replacing battery and if so, did you return them to their original position (normal as opposed to clear cmos)? If the jumper is still in the clear Cmos position, the board will not boot.
Try changing the Cmos battery, it may appear to work but may not be suited to the board
Disconnect all drives except the hard drive, unplug usb and sound cables, if fitted, remove graphics card and either test with another one or use the onboard graphics.
1helpful
I have a ps/2 keyboard but my ps/2 keyboard com port not working. so i sold a USB keyboard but my CMOS settings are enabled only OS.so i canot entre CMOS setting by keyboard
Unfortunately BIOS reset will not help you, the default setting for USB keyboard support is set to OS and you need set it to BIOS. I would recommend you to go with your mainboard to a specialized service, sometimes the problem is only a defective capacitor. If you reset your CMOS, the first boot device will be set to Floppy. You could try updating your BIOS to the latest version (maybe in that version the USB keyboard is set to BIOS) but I don't know if you can create a batch file to update the BIOS automatically, without confirmation from keyboard... The reliable solution is the technician. You can also try to connect your PS2 keyboard to the mainboard using an USB adapter but as I know in that case the keyboard is treated as an USB device...
If this is the solution for your problem, please rate my post, otherwise give us more details.
Regards,
Andras
1helpful
Asus v6j bricked bios flassh gone bad, i need help to reset, pulling battery not working.
Did you pull the Cmos battery. Also on the mother board should be a switch or a jumper that should reset the Bios, or shock it out of its brick state.
2answers
ASUS LGA775 mother board
1.Power down your PC.
2.Locate a rocker-style switch at the back of your PC (if applicable), and switch it from the on position (I) to the off position (O).
3.Find the 3-pin jumper near the power supply, typically labeled "clear cmos" or "reset bios".
4.Remove the jumper from the default position (typically connecting the 1st and 2nd pins).
5.Replace the jumper to connect the 2nd and 3rd pins.
6.Push the power button on the front of your PC once.
7.Wait a minute.
8.Return the jumper to its default position, connecting the 1st and 2nd pins.
9.Move the rocker-style switch at the back of your PC (if applicable), to the on (I) position.
10.Power on your PC with its front power button.
If it doesn't work go to alternate options
Alternate Method
1.Locate a rocker-style switch at the back of your PC (if applicable), and switch it from the on position (I) to the off position (O).
2.Remove the CMOS battery. This should be a regular 3V, round, flat watch battery.
3.Wait at least 5 minutes.
4.Reinsert the CMOS battery.
5.Move the rocker-style switch at the back of your PC (if applicable), to the on (I) position.
6.Power on your PC with its front power button.
Alternate Method
1.Turn on your computer and press the key on your keyboard to enter the BIOS. This is typically the Del (delete) key. Pre-built systems from major manufacturers may use a function key such as F1, F2, or F10.
2.Go to the last tab or page of your BIOS.
3.Select an option similar to "restore factory settings".
4.Save your changes and confirm your selection if necessary. This will often be combined with the process of exiting a BIOS. Some BIOS types may have this as a separate option such as "F10: Save Changes".
Top ASUS Computers & Internet Experts
Grand Canyon Tech
Grand Canyon Tech
Paul Bade
Are you an ASUS Computer and Internet Expert? Answer questions, earn points and help others
