I appreciate your post, Trent!
Based off the information you have provided your Frigidaire washer is displaying an error code of E41 and the door is locked and will not open. An E41 error code means that your main control board thinks the door is open. I would recommend performing a reset on your washer and you can do that by disconnecting power from your washer for at least ten minutes. If that does not help correct your issue it could be a possible problem with your door lock assembly, control panel, or wiring harness. You may need to seek assistance from a professional technician to avoid unnecessary part purchases. I hope this is helpful to you. -Matt
I appreciate your post, Josh Orenstein!
From my understanding your Frigidaire washer is displaying "PAU" and "E41". "PAU" normally displays when there is an interruption to the cycle and "E41" means the main control board thinks the door switch is open. Either code can display due to a faulty door latch assembly, door strike, or main control board. You can attempt to perform a factory reset by holding down the Start/Pause button and Select button until a signal sounds. Also review the door latch and strike to see if there is any visible damage that could cause a short within the components. If there is no visible damage you may want to consult with a technician for proper diagnosis and repair of your washer. Hope this information is helpful to some degree. -Matt
