The belt is made by BANDO and I believe is the Bando STS 60 S3M 471. Call their service number 1-800-829-6612 and ask who their distributor is in your area. They will tell you and you can order the belt through them. Double check the numbers on your old belt to make sure they match what I've written above, but that's the number on the Breadman TR444 I'm working with.
BeltFrog sells the Bando 60 S3M 471 belt here.
Not a solution, but I called the manufacturer (Salton) and they do not sell replacement belts.
A plastic ring on mine is broken and I have no idea where to find a new one. Any ideas?
I have a Regal Kitchen pro bread machine model k6725. I am also in need of a drive belt any ideas?
I have a Breadman tr444 with a stretched belt. Where would I be able to order the belt from.
You can make a belt of any size lenght just go to Mc Master Carr.com . If they dont have the one you need in stock , they have snap toghther ones.
I have the same problem, but producer do not provide replacement belt.
where do I find a timing belt for the TR444 Breadman. It's about 18" long x about 3/8" wide with approximately 160 teeth. The belt is made by Bando marked 8TS 60 3SM 471 but I can't find anything on it.
