Panasonic TOUGHBOOK CF-18 Tablet PC Logo
Posted on Dec 21, 2009
Panasonic TOUGHBOOK CF-18 Took out HD to reload windows as it would not load but stuck at the safe / last known good config etc. Loaded XP onto HD via an ACER laptop and reinserted it into ToughBook - same problem. So put ACER HD in Toughbook - same problem back in ACER no problems. Could it be the FPC ide cable? It recognises both HD's and their capacities but that is all. THx Ruth
Anonymous
Level 1:
  • Contributor 23 Answers
  • Posted on Dec 21, 2009
Anonymous
Contributor
Level 1:
Answers
23
Questions
0
Helped
13286
Points
85
I think your actually having issues getting it to run on the toughbook because it uses different drivers for everything from the Acer computer. If you press F8 while booting up you can choose the option "Disable automatic restart (of system errors or something)". Then when the machine boots up you should get a blue screen giving you an error code like "IRQ_EQUAL_TO_OR_GREATER_X Error: 0x0000005f. You could try to see what the message is trying to tell you to resolve it but the error msg would likely point to the driver that its trying to load that's most likely different from the toughbook you have. I'd suggest getting an external cdrom/dvdrom and install windows from a disc onto the toughbooks hd while its in that toughbook machine.
Rick Kirby
Level 1:
Problem Solver:
  • Contributor 8 Answers
  • Posted on Nov 20, 2014
Rick Kirby
Contributor
Level 1:
Problem Solver:
Answers
8
Questions
0
Helped
10565
Points
10
You cannot load your HD on another laptop and have it work on a Toughbook as the drivers are very different.
Toughbook cf-18 cannot boot thru window. it come out with a start using safemode, then go into window , then blue screen with "a problem has been detected and windows has been shut down to prevent damage...
Yu possibly have a virus
You will need to format the hard drive and reload Windows if this doesn't work you will need a new hard drive.
Try to "defragment the hard drive 1st. check the disk for errors.
1helpful
2answers
I need to buy a CF-18 HDD caddy and HDD where can I find one
Hello there:
Here is a couple of links for this for you to consider
I know that ebay has them but here is a couple of diffferent places for you to look at
  1. Hard drive for Panasonic cf18 - TabletPCBuzz - The Best Place to ... 3 posts - 3 authors - Last post: Aug 11Hard drive for Panasonic cf18 General Tablet PC Discussion. ... The ruggedness comes from the drive cage/caddy, not the drive itself. ...
    www.tabletpcbuzz.com › ... › General Tablet PC Discussion - Cached - Similar
  2. Replacement HDD for Toughbook CF-18 - CNET Miscellaneous laptop ... 7 posts - 2 authors - Last post: Nov 6, 2007... HDD for Toughbook CF-18 - Get tips and advice on this topic, ... to purchase is a caddy (shopping for a good price), HDD,(naturally, ...
    forums.cnet.com/5208-7587_102-0.html?threadID=270788 - Cached - Similar
Where can I download a Toughbook CF-18 Tablet PC Recovery Disk, mine disappeared. rc
Finding a complete recovery disc is prooving difficult. i have found a couple of alternatives to getting a complete install on disc, but they do take a little bit more time.
if you have a copy of the windows which you wish to run your system on. which nowadays arent hard to comeby, then you can use this link as a driver and compac software restore disk
http://www.user-guides.co.uk/cddownload/Panasonic/PanasonicToughbook/Panasonic-Toughbook-CF-18-XP-Driver-CD-Recovery-Restore-Disk-108878.html
however these downloads / cd'a have to be purchased. i really wouldnt bother with it. drivers and apps for compac arent a must have and usually just do things to make the GUI fancey or easy to use. most drivers will be picked up on windows install and the rest wont be hard to track down. a standard windows install is surfice for most things and runs quicker than an install full of tosh little programs.
2helpful
2answers
My touchscreen dont work after re-install windows xp.
try looking on the restore discs for drivers, use the explore option after you right click the cd with disc loaded if not there then go to mfg's website and try looking under support /downloads. you didn't mention model or make, the drivers are on the website in any case. you will get most current drivers from there. hope this helps. good luck
9helpful
3answers
HOW TO INSTALL WINDONS XP PRO ON TOUGHBOOK CF-18
XP can not be installed from usb as the bios does not enable it. Plug the ide hard drive into an older desktop system and install from boot on cd. Once all files are copied over then you need to copy the i386 folder over from the cd. Reinstall the hard drive into the toughbook and carry on the install from there.
Trouble booting!
You could attempt to boot to safe mode, and run the Start> System Recovery > PC Recovery Application.
Otherwise, I'd boot to safe mode, select start, run, type: msconfig, select the startup tab, remove any unwanted startup items that may be causing the system crash.
Hope this helps.
Panasonic touchbook cf18
When I touch the touch pad my screen display goes off. it comes on sometimes by itself or when touch pad is touched. I have connected the toughbook to an external dispaly and can work no problems. help
Top Panasonic Tablets & eReaders Experts
k24674
ADMIN Andrew
ADMIN Andrew
Are you a Panasonic Tablet and eReader Expert? Answer questions, earn points and help others
