Hi there!!!! ive got an acer desktop E500 and the problem is that i need to remove the dvd drive but i have tried to take from the back but it only goes back about 3 cm and then it stops , i have taken the pins that secures the drive to not slide back but after 3 cm sliding to the back it stops, i wonder if there is any other pin the other side or not !!?? hope that you can help me with that !! tks again heres my email!!! [email protected]
Back? dvd.cd drives usually slide out the front.i think ur try to push a door that u have to pull. rating please. get back if not the solution
rating please
if the drive had to be taking out the front ,that would make my advice correct.Which i knew it comes out the front you don't even hsave to answer that. So how come you would only rate my solution like you did?Maybe you made a mistake.I didn't feel you needed more in depht instructions cause you made that far,but i always go back to check if i helped the needed.BBut to see that ranking ,its kind of disturbing.i 'm new at this forum,but i like the concect so i participated.Wasn
THANK YOU
I have seen some computer towers where the drive will slid out through the front. You have to take the plastic covering off the front of the computer first.
MATE TOWER MADE BYE ACER MAKES MINITOR NOT WORK 1 LIGHT GREEB1 littl2 RED LITE WAS WORKING GOOD!
as you see,only about 3 cm of the drive come off the pin and the green clip i have taken off but i wonder if the other side is other pin that doesnt let the drive slide back, but the problem is that i cant take the other part because is sealed!! tks for your time hope to hear from you soon!!!
tks mates for your help!! i know now that was easy ,but im not a very good tech on computers, so ,tks very much for your help!! really apreciated!! tks again!!1 and hope to count with you in the future!!
tks mate!!! i didnt know the rating was so important!!! tks again/!!!1
I have the same problem trying to removed the DVD drive from my Acer M5630. How did you remove the front cover to slide it out the front?
exactly how do i take of the front cover, ive tried many things, but there doesnt seem to be any screws that connect the front, i have the same computer (acer aspire e500)
