I have a pro form performance j4 treadmill. i cannot locate the safety key and the unit will not power on. is this the reason? also will the standard safety key for proform treadmills work for it?
It seems like you're experiencing issues with your Pro-Form 580X treadmill. Here are some troubleshooting steps you can try:
Safety Key: Ensure that the safety key is properly inserted into the console. Treadmills typically have a magnetic safety key that must be in place for the treadmill to operate.
Circuit Breaker: Check if there's a circuit breaker on the treadmill. If it has tripped, reset it. This is often located near the power cord entry point.
Power Source: Verify that the treadmill is properly plugged into a functioning power outlet. Test the outlet with another device to make sure it's working.
Calibration: Some treadmills require periodic calibration. Check the user manual for instructions on how to calibrate your specific model.
Check for Obstructions: Ensure that there are no obstructions or debris around the belt or underneath the treadmill that might be preventing it from moving.
Lubrication: Treadmill belts may require lubrication. Consult your user manual for guidance on how to lubricate the belt properly.
Control Panel: If the control panel buttons are not responding, it could indicate an issue with the console or wiring. You may need to contact Pro-Form customer support or a technician for further assistance.
If none of these steps resolve the issue, it's advisable to reach out to Pro-Form customer support or a qualified technician for a more thorough diagnosis and potential repairs.
www.sportsmith.net/.../product_support%5CProForm%5CPFTL391100... Thank you for selecting the new PROFORM® ZT3 treadmill. The ZT3 ... the keynumber of the part, from the PART LIST near the end of this manual. The number ...
THIS IS KINDA ODD SINCE ALL TREADMILLS HAVE A SAFETY KEY. PLEASE CONTACT CUSTOMER SERVICE AT THE NUMBER THAT IS ON YOUR USER MANUAL OR CALL 1-888-533-1333.
Dear Sir:
Hello , I hope everything is fine.
Please do the following:
o 1
Remove the key from the machine and unplug the unit for safety
purposes.
o 2
Adjust the rear roller adjustment bolts using an allen wrench. The right
bolt should be turned one-fourth turn clockwise and the left bolt should
be turned one-fourth turn counterclockwise.
o 3
Place the key back into the unit and plug it back into its power source.
o 4
Run the Proform treadmill for five minutes to make sure that the walking
belt has fully recentered itself.
o 5
Repeat these steps if necessary.
If the Belt Slip when in use:
o 1
Unplug the unit and remove the key card.
o 2
Tighten the walking belt by turning both rear adjustment bolts clockwise
using an Allen wrench.
o 3
Replug the unit and reinsert the key card.
Thank you in advance, sincerely. Blessing.
E.CUADRA
Managua, Nicaragua. c.a.
First thing I'd try is just using any magnet. I'm sure that's all the key is normally. If that doesn't work, no you cannot use a treadmill without a key. It's a safety measure created by the company.
Here's the key for sale on amazon that goes to your treadmill.
http://www.amazon.com/Pro-Form-Treadmill-Safety-Key/dp/B002YP4KQE
Hope this helped!
Press the Stop and the Speed Up keys down while inserting the safety key. This should get you into calibration mode. Press the Stop key one time. The Time window should read EP:2P. Some newer models may also say FP, Pass, or the like. This means that it passes the EPROM test. If you cannot get into calibration or if the EPROM test fails then the upper console will have to be replaced. If you get pass to this point then proceed with the calibrating the incline and speed. Press either incline key and the incline will calibrate automatically. Be careful the treadmill will run at full speed in the next mode DO NOT STAND ON THE WALKING BELT.Press the Speed Up key and hold it down until 85 is shown in the Distance window (some models may show the 85 number in another window). If the top speed of the treadmill does not match the displayed speed on the computer console, adjust the max speed potentiometer (pot) on the motor control board. This is the board that the red and black motor wires connect directly into in the motor area. The Max Speed pot is clearly labeled The max speed potentiometer is a small square with a mobile center and is located in one corner of the board and is labeled MAX SPD. It is near the harness that carries the speed signal labeled H,W,L. Using a small insulated screwdriver adjust this potentiometer clockwise to speed up and counter-clockwise to slow down the max speed of the treadmill. A tiny turn of this potentiometer will make a big difference in speed so be careful when making adjustments. It is not important to get the speed set exactly at the max speed of the treadmill but do make sure to get the speed within .2 MPH of the max speed of the treadmill. For instance if the max speed of the treadmill is 10 MPH, make sure to have the speed set between 9.8 MPH and 10.2 MPH. Some models have a 12 MPH top speed, so please check your manual if you aren’t sure. After completing calibration of the speed, press the Speed Down key. The treadmill will automatically return to 0 MPH. Please allow the unit to stop completely before continuing.Press the Stop key once and remove the safety key.
You may need to calibrate the incline. Do this with the following procedure.
Safety key out
press the stop and speed up buttons at the same time while inserting the safety key. (you are now in diagnostics)
press the stop button one time only.
now press the incline up button (incline motor should start moving up)
incline will go up to the top and then all the way to the bottom. when it gets done you can remove the key. Reinsert the key and you should be operating normally.
Good luck Tim
Do a Calibration on the treadmill. Take out the safety key. With 2 fingers, hold down the stop button and the speed up or spped plus button. keep holding them down as you insert the safety key, then let go of both.
Press the stop button 1 time, you should see all 0's in the windows, or EP 2P or something weird like that.
Press the Incline up button and then wait. If the incline go up until it stalls then down until it stalls the stops at the bottom, the you are recalibrated, take out the safery key and put it back in to see if all is well. If the incline takes off up again without touching a button, the you have wiring problems or control problems. Call service company to get it repaired.
