DVD player displays "PROTECT" and locks up. It doesn't always happen, but it happens frequently. It happens with Blockbuster, Netflix movies, and even with the DVD cleaner disc.
I have the exact same problem. It started occasionally but now it happens all the time, even without any disc. I didn't try to clean it yet...
The protect indication is because of a fault detected in the amplifier section. If this appeared occasionally before and cleared itself, it suggests bad connections. If you know how to solder, open up the unit and resolder any connections that appear grainy or have rings. That may solve the problem.
Dan
If the subwoofer and other speakers were included with the system, THAT is what they're designed for. Mixing and matching with other products is usually discouraged if not forbidden.
If the problem returns with connection of the sub it may be defective or on its way out. Internal damage to the voice coil from being overdriven could have melted or worn through the insulation and it would cause intermittent undesired electrical contact or load variation under certain conditions, like high volumes.
If your speaker level settings are unusually boosted for the sub you may be overdriving it.
I know that almost all new equipment since 99 or so on up has these. They are too sensitive. This is a system program that will put stereo in protect mode when turned up loud or have a lot of bass on to stop from blowing audio outputs.
yes u can connect an externel dvd player to your sony dav s 500...
you have
composite video input X 1 and
analog input X 1.
so you can connect the RC output pins of externel dvd player to the input of composite video and analog left and right audio inputs to the SONY DAV S500.
C31 usually means a motor error. In your case, it sounds more like the loading sequence is not completing. Can you please confirm that the model is the DAV-FX10 system?
Umm, this isn't just a DVD player, It.s an amplifyer too. Just leave the speaker cables alone, plug in the new dvd player into the "video2" jack, yellow cable onlt. Then,plug the audio cables into the video2 jacs (the red and white ones). Select "video2" on the SonyDAVS300 and "video2" on the tv. Insert the dvd into the new player and enjoy. It's screwy but it works through the amp and sends the picture to the tv.
Well for the issue of the audio it usually protects when you are approaching the maximum that the internal workings of the system can handle. This also happens when it is overheating. Try to limit your maximum usage of the system to 5-10points below may.
