Question about Nokia 6680 Handheld
Unable to perform bluetooth operation!how can i solve this problem???help me plz!
Null
  • 16 more comments
  • idaline Mar 10, 2008
    unable to perform bluetooth operation n76 how can i get it fixed
  • toutratus Apr 14, 2008
    Also having the "unable to perform bluetooth operation" when trying to turn on the bluetooth of my N82. Did anyone find the solution to it?
  • hypestar May 13, 2008
    when tring to turn on bluetooth it says unable to perforn bluetooh operations. how do i fix this?
  • Anonymous May 14, 2008
    same issue with the N82. sometimes restarting the phone helps, but not always, so probably it is not a solution. not sure if it is a hardware issue... I hope not!
  • rash77 Jun 12, 2008
    Hi all,
    I've bought my N82 about a month ago. ANd now I'm having this "Unable to perform bluetooth operation" issue also. But this was triggered after I install new themes into my phone. Once I switch theme, the bluetooth somehow will give this problem. Initially if i power on and off my phone is okay but now totally can't activate my bluetooth at all!! =(((
    Will appreciate if anyone can suggest some solution to it. My firmware version should V20 one..the latest one...
    Rgds,
    Crossie
  • vespinoza Oct 14, 2008
    So, will Nokia fix it for you?
  • bajram_kola Nov 26, 2008
    thank you for your about for bluetooth.you is good adress.bye bye!!!
  • atish0 Jan 06, 2009
    i Hve this E50, the blue tooth was working with my old laptop few months agao. Now when I try to start the blue tooth I get the message Bluetooth operation failed
    Any solution, I even re-loaded the firmware using the latest nokia pc suite
  • Anonymous Feb 01, 2009
    unable to perform bluetooth operation!how can i solve this problem?
  • Anonymous Mar 02, 2009
    Same problem also after having updated to the new firmware 31.0.016
  • othiuz Mar 11, 2009
    "unable to perform bluetooth operation!how can i solve this problem???help me plz!"
  • layla_durkin Mar 12, 2009
    I have just got a new nokia 6220 clasic, and when i go to switch the bluetooth on it says... unable to perform bluetooth operation! could anyone help??
  • Anonymous May 16, 2009
  • yang dailan May 07, 2013
    how about my nokia n71 my bluetooth also unable to perform
    could it be possible to fix my n71 bluetooth it also having a problem. "unable to perform operation"
    what actions could i take? any suggestions? thanks looking forward in to it.
  • charmzbelangigue
    charmzbelangigue Mar 10, 2014
    unable to perform bluetooth operation e63 how can i fixed this
  • Anis Khan Jainan Apr 16, 2017
    My nokia6120 shows unable to perform operation why please somebody hlp me
Posted on Oct 15, 2008
  • nabeelsheikh May 27, 2011
    thanks dear it worked
  • 4 Answers
Part of the solution: This step is supposed to help diagnose if its a software o hardware problem.
Press *#2820# and it must show something like "Bluetooth adress: XXXXXXXX" (where XXXXXXX is a series of numbers and letters). If this message does not appear, then we´re talking of a HW problem, bluetooth module shall be reheated (don´t know exactly how this is done) or replaced. If the message shows then its a SW problem and a hard reset or upgrade could solve the problem.
Hope this helps, and if so, post result.
Posted on Sep 15, 2009
  • 1 more comment
  • mamushmilano Sep 24, 2011
    thank u so!!!!!!!!!!!! lovely successfully done!!!
  • muhammad_aer
    muhammad_aer Sep 22, 2012
    message appear"bluetooth address:"but no letters or numbers appear please help me.
  • ncrox_fb
    ncrox_fb Mar 03, 2013
    lap
I am wondering if there is a way to connect the N82 to the Bluetooth it can perform uable to connect bluetooth operation
is there any solution
Posted on Feb 24, 2009
Posted on Feb 01, 2009
Unable to perfrom bluetooth operation faild
Posted on Apr 15, 2009
    New Friend:
Nokia 6120c.i've same problem.i Pressed *#2820# and showed me "Bluetooth adress: blank or empty" help me please...
Posted on Mar 22, 2012
Solution #7 posted on Jul 24, 2009 unable to perform bluetooth operation!how can i so - 0%20ratings_thumbs.gif
nagendrenk92
Rank: Apprentice
Rating: 0%, 0 votes
please beleave me.....it works
take the back cover inside there will be a imei coad ....there u shoud press about 15 times and turn on
it will works .........
this will be stupid solution it will work . if doesn~t work contact me:90030620380(india) by sweet
k.nagendren Posted by k.nagendren.. this one works for me...
Posted on Aug 15, 2009
  • boyphea Aug 17, 2010
    It mean, switch off phone right? and leave battery?... Please detail about it too... I am not really understand...
Please beleave me.....it works
        k.nagendren
Posted on Jul 24, 2009
    New Friend:
  • 6 Answers
I don know exactly how to repair it, but i think formatting the cell might be useful,
in this case, turn ur phone off, pressing keys: */3/green key together, and turn ur phone on.
remember to remove ur memory card, copy ur contacts to sim card or ur PC, all the materials will be removed,
hope workin
Posted on Apr 20, 2009
    New Friend:
Hellow sir my nokia 5800 unable opeartion perform and same problem fm radio plz.,help me sir
Posted on Apr 05, 2013
    New Friend:
Help for my 6120 bluetooth unable to perform
Posted on Jul 27, 2012
    New Friend:
How can i solve this unable to perfome bluetooth ioptin could any one tell me pls
Posted on Jul 15, 2010
    New Friend:
I have the seemproblem
Posted on Mar 18, 2010
I have my nokia x6 16GB w/ the same problem:bluetooth unable to perform operation:try to check *#2820#if no.
Posted on Feb 22, 2012
    New Friend:
Hi,sir i am using a nokia c6
bluetuth not working plz help me..
Posted on Jul 01, 2013
    New Friend:
I'm facing the same problem too. when i went to authorized nokia service center, they told me that my 1-year warranty expired last month. If I still want them to fix it, they will charge me RM50 (USD15) but they dont guarentee it will work. If something bad happen to my phone during repair, they will not be responsible. How such this thing can happen?
Posted on Apr 20, 2010
    New Friend:
I checked *#2820# . The blutooth number is showing . But the problem is not solved
Posted on Mar 01, 2016
I have a NOKIA E90 COMUNICATOR whit same problem. mobile was in nokia service and it is hardware problem whit motherboard. to expensiv to repar. **** :)
Posted on Sep 18, 2008
6ya staff
SOURCE:
Nokia x6 unable to perform bluetooth operation
Hi first of all restore the phone setting to default.If possible better to reset it by selecting "Restore All"(this will erase all your phone data).If there is no effect please visit nearest mobile repairing shop.Because, your problem is having some hardware/software problem which can only be repaired by mobile technician.Thanks for visiting fixya
Oct 31, 2012 | Nokia X6 16GB Cell Phone
My bluetooth s nt workng.. Its shows 'unable to perform bluetooth operation' plz help me
Can you be lil more specific in mentioning that your bluetooth handsfree is not working or your mobile has this problem??
Jun 08, 2011 | Nokia N73 Cellular Phone
My x6 unable to perform bluetooth operation
Its a tapping method. Plz.. visit in nokia website, simple solution is given! Sure it works in nokia x6... I hope it will help
Dec 12, 2010 | Nokia X6 16GB Cell Phone
Unable to performed bluetooth operation
check *#2820#
if your able to get bluetooth address then its software problem,hard reset your mobile,
Hard reset-*#7370# and press Yes to confirm initialization. Back up your data plz.
else its hardware problem
change bluetooth IC 100% solution
Please do rate the solution if the issue is resolved or post a comment for further assistance.
thank you for using fixya have a nice day:-)
Jul 26, 2010 | Nokia Cell Phones
My bluetooth is not working in N73 mobile .When i turn on my bluetooth this error appears " unable to perform bluetooth operation " can some1 tell me why ?!
My Bluetooth is not working in N73 mobile .When i turn on my bluetooth this error msg appears " unable to perform bluetooth operation then plz help me someone
Mar 06, 2010 | Nokia N73 Cellular Phone
plz take a update ur farmware ...
Sep 17, 2009 | Nokia 7610
Problem
reformat your phone.
May 15, 2009 | Nokia 6630 Handheld
Bluetooth operation problem
you need to go technician then ask them to reformat your n70 phone,so that it will work well.
Nov 22, 2008 | Nokia N70 Cellular Phone
This is because u may have virus in ur mobile or memory card.This problem can be overcome by formatting ur memory card by ur phone itself or by using card reader in personal computer..............
Apr 23, 2008 | Nokia N72 Cellular Phone
6630 unable to perform bluetooth please help me....
Sep 26, 2006 | Nokia 6630 Handheld
Nokia 6680 Handheld Logo
15,040 people viewed this question
Top Nokia Computers & Internet Experts
Anthony Ward
Anthony Ward
k24674
Ekse
Are you a Nokia Computer and Internet Expert? Answer questions, earn points and help others
