Hi, there is no reset switch. The original fan was not the culprit. The culprit will be the microcomputer(PCB). This board routes the start signal, and power to the fans and compressor unit. The initial intervals are set be the cold control device inside the refrigerator, and freezer. The Microcomputer has several relays mounted on the board. One of the fan relays have failed. This will require you to replace the entire Microcomputer. This will correct the issue. The part number for the replacement computer will be 4389211
It is mounted on the compressor platform, under the control board housing cover.
Yes, I agree with Micheal. The control board is most likely the cause. If you have a hard time finding it new, you can have it rebuilt at www.fixyourboard.com
For car running hot and overheating issues, I suggest to you go
through this help links. Click this link below and go through the
troubleshooting procedure to take care of the problems: ----Car runs hot? http://howtobyme.blogspot.com/2011/11/car-runs-hot-in-traffic.html
-----------All types of car overheating problems and
troubleshooting?
http://technoanswers.blogspot.com/2011/11/all-types-of-car-overheating-problems.html
Car freeze overnight and started overheating while driving?http://technoanswers.blogspot.com/2012/01/car-freeze-overnight-and-started.html-----------Engine Overheats and heater blowing cold?
http://howtobyme.blogspot.com/2011/11/engine-overheats-and-heater-blowing.html
Car overheats and Air blows hot at idle?
http://howtobyme.blogspot.com/2011/11/car-overheats-and-air-blows-hot-at-idle.html
--------overheating? http://schematicsdiagram.blogspot.com/2011/12/buick-century-overheating.html
----------Car engine Overheats and transmission starts slipping?http://schematicsdiagram.blogspot.com/2011/12/car-engine-overheats-and-transmission.html
----------This details will help.Thanks.
temp gauge goes erratic?
http://technoanswers.blogspot.com/2012/01/heater-blows-intermittently-and-temp.html
Temperature gauge keeps fluctuating up and
down close to red?
http://technoanswers.blogspot.com/2012/01/temperature-gauge-keeps-fluctuating-up.html
troubleshooting?
Temperature gauge does not move and no heat
when heater is ON?
http://technoanswers.blogspot.com/2012/01/temperature-gauge-does-not-move-and-no.html
