1998 Cadillac DeVille Logo
Posted on Dec 22, 2009
I need a picture/or diagram of the serpentine belt routing on a 1998 Cadillac 4.6l north star engine. Car is a De ville
Anonymous
Level 1:
New Friend:
  • Contributor 1 Answer
  • Posted on Jan 13, 2010
Anonymous
Contributor
Level 1:
New Friend:
Answers
Questions
0
Helped
1802
Points
9
I need a diagram of how to replace a serpentine belt on a 1998 Calilic 4.61 north star engine
Replace north star engine belt
I found this picture, it didn't say northstar. The tensioner in picture has a half-inch cut-out. Use a 1/2 rachet or break-over in cut-out, usually the longer the handle, the better. You pull the tensioner one way or the other to get slack in the belt, then remove belt from accessory pulley.
SERPENTINE BELT DIAGRAM FOR 1998 CADILLAC DEVILLE 32V NORTH STAR V8
http://www.fixya.com/cars/t4749862-north_star_belt_diagram
1989 cadillac eldorado 4.5l i need the diagram for the serpentine belt
okay, let me try to help you, its a 1989 eldorado 4.5 engine. here you are a diagram of the belt routing, hope this helps . good day.2_17_2012_8_59_07_pm.gif
Diagram for a 2003 Cadillac cts serpentine belt
Below is the master help link provided to go through belt routing diagram:---Timing belt, drive belt, serpentine belt, accessory belt, fan belt, engine belt routing diagrams for all types of car models?
Click the link below: ----
http://carbeltrouting.blogspot.in/2012/02/timing-beltdrive-beltserpentine.html
----------This will help. Thanks.
2answers
Need diagram for serpentine belt installation
there should be a white decal on the upper rad support bar that shows you the belt routing,in not then draw how the belt is routed before you take it off the car.the parts store may have a routing diagram,if the belt broke then if you know someone with the same type and engine size maybe they will let you look at the belt routing.you can also go to the library and take out a book or draw the routing from the book for your car.
3helpful
Sepentine belt routing diagram for a 2001 cadillac dhs with north star engine
http://www.google.com/search?client=ubuntu&channel=fs&q=northstar+belt+diagram&ie=utf-8&oe=utf-8
16helpful
North star belt diagram
Northstar belt routing diagram.
This diagram should also be on top of your engine somewhere, usually on the plastic cover on the radiator.
7helpful
Show routing diagram for serpentine belt for a 1994 Cadillac De Ville
CLICK on the following LINK. It has all the Diagrams for your Belt that you will need.
If you would: Before Clicking let me know if this helped you, or if you have any additional information or questions. Feel Free to contact me at FixYa.com!
Thanks!
http://www.2carpros.com/car_repair_information/year/1994/make/cadillac/model/deville/1994_cadillac_deville_drive_belt_routing_diagram.htm
2helpful
Access to odd numbered spark plugs on North-Star V8
To gain access you have to remove the ignition coil pack. There are only 4 10mm bolts holding it on. Also remove the cross over to have more room.
7helpful
2answers
Need diagram of drive belt assembly forcaddy
You didn't list your motor size so please pick the applicable diagram:
Accessory serpentine belt routing—4.8L, 5.3L & 6.0L engines
Accessory serpentine belt routing—5.7L engines with A/C
Accessory serpentine belt routing—5.7L engines without A/C
Accessory serpentine belt routing—6.5L Diesel engines
Accessory serpentine belt routing—7.4L engines
Accessory serpentine belt routing—8.1L engines
Top Cadillac Experts
ZJ Limited
ZJ Limited
Ronny Bennett Sr.
Ronny Bennett Sr.
Thomas Perkins
Thomas Perkins
Are you a Cadillac Expert? Answer questions, earn points and help others
