Hey friend, thank you for your post!
I see that your Frigidaire washer, FWT449GFS2 is not entering the final high spin cycle. It is possible that you could have a defective motor or timer. Since it could be any one of these underlying issues I would recommend you having a professional come out to the home for the repair of your washer. -Matt
Hello serratosal - Based on the symptoms you are describing, you may have a broken belt or a faulty control board. Often when the belt is damaged, the unit will try to spin but it causes it to burn and eventually blow the control board. I would suggest contacting an experienced service technician to determine the root cause to reduce the risk of unnecessary parts.
There can be many reasons why your dryer will not start or turn...
The most common causes are the belt breaking or jumping off, or the motor going bad...
Here are a couple of tips that I wrote will help you to figure out why your dryer will not run...
Dryer Repair - The Dryer is not Turning
Dryer Repair - The dryer will not start
heatman101
