Blinking blue light with a clicking noise coming from the back no display. Unplug for an hour plugged back in and held the pwr btn and got sound till the pwr was pressed and back to just a clicking sound and blue light flashing
1. is light on in side when you open the door. If not check breakers or fuses. 2. Can you hear the compressor running. If not do you hear any clicking sounds. 3. If you hear clicking sounds, try putting a fan on compressor and unplug refrigerator. 4. Wait one hour. 5. plug back in. If compressor starts let it run and see if it cools, if it doesnt, call service man. 6. If it goes back to clicking, call a service man. try this
What you need to do is look for the Power Wire coming from the front of the PC. It will probably say something like PWR BTN on it. It will be two wires twisted together. Now on the bottom right of your motherboard there will be pins sticking up, probably about 12 of them. 2 of the pins will have a label printed on the motherboard that will say PWR BTN. Just plug those in hit the power button on the front.
i just reset mine as mine would not turn on, i held it for a few seconds ant then turned it on and it came on! but mine is chargint at the moment, but the flashing light is red! i thought it was supposed to be green??? Can anyone help?
You can buy a used monitor about $50.00 in the US. or You should take the monitor to an authorized repairman. IT IS NOT recommended to fiddle by banging a defective unit WHICH has HIGH voltage running through it.
pwr on button on the receiver push in and hold for 30 seconds release
unplug pwr cord 15 minutes - then replug in.
this is the factory reboot
should fix the problem.
if not fix - then its ****.
i've not tried this yet... but will when I get home
I alreeady encountered this problem. I fix it temporarily.... I just turn it off, Press all the Function btn and the recall btn, then pres the On btn... wait for 2 sec then release the func, recall btn. Then I already able to use the PC for about o hours without interrupted signal (on/off). I call it temporary fix because whenever you turn off the Monitor, you have to do the same process again..
Try it it can help.. Thnaks.... If you already find solution , maybe you can share it to me too .. Thanks..
