Kenmore 98702 Stacked Washer/Dryer Logo
Posted on Dec 24, 2009
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Water under stackable washer dryer
I noticed some water on the floor under my stackable washer/dryer combo. Its a Kenmore
Anonymous
Level 3:
  • Master 999 Answers
  • Posted on Dec 24, 2009
Anonymous
Master
Level 3:
Answers
999
Questions
Helped
310992
Points
2740
The front panel comes off and you will be able to trace the water source. These combo units spin immediatly and if the drain is slow the water will spin up over the edge of the tub during drain.
Eric
2answers
My Kenmore stackable washer/dryer combo, model 417.94702300 suddenly overfilled with water and started leaking through the back. How can I gain access to the pressure switch tube to clear it?
The tub seal could be broken or or ripped or torn and the tub bearing and the tub seals both need to be replaced then for your washing machine and dryer machine combo.
Need to replace belt
Search Results
    How to repair a KENMORE double decker washer&dryer ...
    ? 4:59
    www.youtube.com/watch?v=Rc_ZGugYBTY
    May 31, 2014 - Uploaded by MrProductionist
    How to repair a broken dryer belt from a Double Decker Washer and Dryer. ... I have a Kenmore stackable Washer-Dryer, and the dryer belt is ...
How do I replace the fuse in the dryer for stackable Kenmore model 417.98702891
This is an excellent source. Click on the link
http://www.repairclinic.com/Shop-For-Parts/a17b6d632276-x6d6f64656c/Model-Model-41798702891-Kenmore-Washer-Dryer-Combo-Parts
2answers
98702 Stacked Washer / Dryer Your question about 98702 Stacked Washer / Dryer has been posted. Mom has a Kenmore stackable washer. She ran water in for a load and the water ran out of the washer and onto...
Get the control panel off and remove the water pressure tubing. Blow it out and reconnect to pressure switch. Remove water so that pressure can once again build inside the tube. Retry>
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
Mom has a Kenmore stackable washer. She ran water into the washer and all the water came out on the floor.
This seems like a difficult problem but is an easy fix. Remove the hose from the water level switch and blow out the sediment like this:
Service manual and more photos HERE
Kenmore stackable washer wont work on Cold cycle only hot water
Here are a couple of tips that I wrote to help people that are having problems with the washing machine not filling...
Washing Machine2_bing.gif Problems No Water
http://www.fixya.com/support/r3880845-washing_machine_problems_no_water
Washing Machine Fix Washing Machine No Water
http://www.fixya.com/support/r3880533-washing_machine_fix_washing_machine_no
heatman101
1helpful
Balancing problem Frigidaire stackable front load washer/dryer
Check the Vibration damper rods to be sure that...
1. They are there and mount is solid.
2. If they are broken in 1/2.
3. The plastic knuckle mounts are not missing/broken.
4. There is oil in the shock absorber/spring section of the rods.
Also - there are suspension springs on the bottom of the tub that could be broken and/or missing.
Replace/repair as necessary.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Alexander
vince
