Posted on Dec 24, 2009
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Hi, i have a ricoh af 3045, i cant input a user code or set admin password because the machine dissplay´s this mesage, you do not have the privileges to use this function.
Adorjani Laszlo
Level 3:
  • Ricoh Master 1,316 Answers
  • Posted on Dec 27, 2009
Adorjani Laszlo
Ricoh Master
Level 3:
Answers
1316
Questions
Helped
457111
Points
2563
Press the clear modes key.Press the clear/stop key more than 3 sec untill the user tool menu appears on the touch pannel.Select the menu number to use by touching the touch pannel display.If the copier is set to use user code function operators must input their user codes before the machine can operate.The copier keeps count of the number of copies made under each user code.User tools 8-9-10-11 are for the user code mode,when you want to use these user tools you should enter the key operator acces code first.
Please connect me for other detailes or help.
Ricoh aficio mp 2000 can't print asking for log in username and password?
Login Issue Assistance
User
I never set any log in details, I have tried Admin,Supervisor with a blank password but not working, please assist
ChatGPT
If you're being prompted for a login username and password on your Ricoh Aficio MP 2000 printer and you haven't set any login details before, there are a few things you can try:
Default Login Credentials: The default username and password for Ricoh printers are often set to "admin" for both the username and password. Try using "admin" as both the username and password to see if it works.
Factory Reset: If the default login credentials don't work, you can try performing a factory reset on your printer. This will reset all settings, including any login information that might have been set. However, keep in mind that a factory reset will also erase any other custom settings you have configured on the printer. To perform a factory reset, you can refer to the printer's user manual or contact Ricoh support for specific instructions.
Contact Ricoh Support
Ricoh 3045 error925
Hi, mahesh Van;
The error code sc925, it mean networking problem, check up your network, will be take care this problem.
4helpful
I have aficio 3045 and i forget my login user name . ofcors i useed " admin " and " supervisor " bat nat work plese can you help me for reset myuser name ? tonk you
try without password just admin or administrator as user name
Long shot but u never know
or supervisor as user name and password
6helpful
4answers
Ricoh 3045 printer stopped printing error code SC545
Hello, you´re found problem in the fusion unit. Clean the thermistor, and try again. Before try it, most reset the Sc code with service code....Good Luck!
1helpful
Can´t restore XP
Yes - it will have (or should have) been set by the former owner.
Allan
1helpful
2answers
We lost the user codes for our ricoh ft4522. how
select user tools, admin , address book you should be able to see the pre programmed user codes. there also should be an option to view or print out the codes
2answers
Aficio 3045 suddenly indicate jamming.
format the hard disk if available check wheather there is not any paper in duplex or in the machine if not then check paper settings if not then execute memory clear if not then replace the registration sensor and exit sensor if not then replace thermistors if not then replace nvram
5helpful
Ricoh Aficio 3228C asks for user name and password
What is the user name and password refering to?
if it is the administrator user name and password try
user name - admin
password -
blank password.
good luck
How do I put a password on Ricoh Aficio 2051 printer?
go in to user tools, system setting, key operator tools or admin. tools. there you can set up password.
10helpful
4answers
Lost admin password for ricoh aficio 3260c.
if u have bios password u shoud do that remove your bios battry from the motherboard for few mints & your password will be reset
Top Ricoh Office Equipment & Supplies Experts
ZJ Limited
ZJ Limited
Grand Canyon Tech
Grand Canyon Tech
Are you a Ricoh Office Equipment and Supply Expert? Answer questions, earn points and help others
