SOURCE: HOW TO CONNECT SAMSUNG LCD TV TO ACER ASPIRE
hi if you laptop has the s-video you can connect that to the tv an it would work
SOURCE: I am having a problem with my Samsung LNT4661FX/XAA
http://techreport.com/search_google.x?cx=010312586752609289257%3Avgpois-b0yw&cof=FORID%3A11&q=LNt4661fx&sa=#692
check this link for more info on the power supply problem.
SOURCE: horizontal lines on tv
The pixels are scanned and organized in an X-Y matix. One of the control ICs has gone 'thermal' and unfortunately on many (not all) sets these circuits are placed by assembly robots as an integral part of the display panel making it very expensive to replace since the pin spacing is too close for anyone to manually replace them. If you have peered inside anyhow, get a couple cans of 'freeze spray' and try look for ICs attached to the back of the display panel and shoot them individually for a second or two, allow some time for the internal temperature to change before continuing while checking the screen for changes. If you can correct (less likely will it worsen) with the spray, you have the right one or two chips.
SOURCE: Purple dots on HD LCD samsung model LNT4661FX/XAA when on.
hi,
your lcd micron tube in the panel had already worn out.
got to replace the panel
