Maytag Neptune FAV6800AW Top Load Washer Logo
Posted on Dec 24, 2009
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
When washer spin the machine stop mark the code ol
  • Anonymous May 11, 2010
    Is the Machine a FAV6800A or FAV9800A T/L? If so what is the error code? Is it dC or uC? Let me know and I will try to help..... Rich
Anonymous
Level 3:
  • Master 526 Answers
  • Posted on Dec 24, 2009
Anonymous
Master
Level 3:
Answers
526
Questions
0
Helped
142991
Points
1214
Sorry I missed the error code oL
oL Machine Paused-Load Wedging….I think that may mean something like the tumblers are jammed up but that’s a guess. I have never seen that error code before. If no one on the forum can help I will give it a try. I need to do some digging in. If I hit a dead end for this error code I will ask on another forum if any Maytag repair folks have knowledge of this error code and it’s cause. We could do some basic troubleshooting if you want to try. If you recycle power on the machine will the machine run a normal cycle?
If you want to dig in and troubleshoot the issue I will try to help. See my last post of how to get into Service Mode. I would suggest reading the Diag codes and see what the machine has logged with past error codes.
Here are links for the Service Manual and parts look up. FAV6800A/FAV9800A Service Manual for reference. Sears Parts Direct for reference.
Waiting to hear back from you….Rich
  • Anonymous Dec 24, 2009
    I just found this for Diag code 40 in the Service Manual....Washer not operating due to tumble not functioning Load bound up.
    LED – Will display “oL The washer is unable to complete its cycle. The paddles cannot move. To continue,
    separate and redistribute the load, then press “start/pause”.
    Is this issue a onetime event or dose it happen all the time?
    Can you restart the wash cycle and see if it completes. If not I would release the washer top from the base and observe tumbler action.
    See Page 33 of the Service Manual this will show you how to release the washer top from the base.
    Wait until the washer fills with water before you release the washer top or you will spray water around. Once the washer starts to agitate the wash load release the top and observe tumbler action. If the tumblers are not rotating this can be a transmission issue. Is this issue a onetime event or dose it happen all the time?
2 Related Answers
Mike
  • 4383 Answers
  • Posted on Sep 14, 2009
SOURCE: washer is skiping rinse and don't spin has code ol
be sure that both water sources are connected and turned on.
Anonymous
  • 15935 Answers
  • Posted on Sep 23, 2010
SOURCE: kenmore washer OASIS errror code OL
OL error means the Motor Controller has sensed an Overload.
The oL code means the motor control board is struggling to power the motor up. If it recurs after removing some clothes - usually this means a new motor control.... or worse - a new bearing.
If it were a problem with the tub floating up, the unit would spin instead of nutate.
Bearing failure in this machine is very common.
I suspect the drive shaft and bearing are the problem. The bearing and shaft are part of the outer tub.
The new outer tub with bearing W10128830 cost approximately $197 dollars.
If you can get access to the shaft it may be an Emory cloth will help smooth things down so that you no longer get the OL code.
This is an ambitious do-it-yourself project... as most appliance repairmen don't understand how this machine operates.
http://media.fotki.com/1_p,srrtbrrfbdbqgkkxgtqsskgwtqkq,vi/bqkfstqqfxrqqbkwgqdxbwsqrwrtq/1/1303472/5961857/image828956817962821589img-or.jpg
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
Whirlpool Cabrio WTW6700TW1 skips wash cycle and stops after 14 minutes to oL
oL is an Overload error. Try running a cycle empty.
If oL (overloaded) appears in display, the load too large. If an overload is detected, the washer will drain any water and detergent in the washer. Remove several items and add HE detergent. Close lid and press START/PAUSE.
oL - Error Code - Washer - Product Help ' Whirlpool
https://www.google.com/search?q=whirlpool+cabrio+ol+error
When machine goes into final spin cycle it gives me a OL code
OL means the washer is overloaded or there is excessive drive load. Go to the link for a full explanation of the OL code and its repair. What might be causing the OL error code on my Whirlpool Cabrio washer...
Kenmore elite washer
hi
unfortunately the programmer is faulty
Washer stops and shows oL over load
The "oL" error code in the Cabrio and Bravo washers means the motor is sensing an overload ("oL") condition. While this could indicate a problem with the motor, it usually doesn't. Most of the time, you'll see this error code when one of two things is going on:
1) There's a piece of clothing stuck between the inner basket and outer tub.
2) The tub is not floating freely, usually because it's seized to the drive shaft by rust and crudus; FYI: this condition is almost always caused by using non-HE detergent in this washer. Also, be aware that, if this is the case, it can be very difficult to remove the basket from a badly corroded drive shaft, could even be a two-man job.
Here is a video to help you get into the machine.
Keep me posted!
Washer comes out of wash cycle stops code ol.run in rinse/ drain cycle,ol stops before comple cycle ,run in drain spin compels cycle
I hate to say it but everything on those machines is controlled by one board which can become faulty at any time. I would replace the control board
2answers
OL error code
Hi jbrundage1. I believe you have a UL error code on the washer. It means that the sensors in the washer are sensing the unit is unbalanced. When the washer is empty, set it to a spin or rinse and spin setting. Run the washer through the cycle empty, as it will help to remove any excess water in the tub. Also, make sure the washer is level, as it is balanced on springs, and that could be throwing the sensors off. I hope these suggestions prove helpful. Sincerely, Melanie, Maytag Social Media Representative.
1helpful
Error on control panel "oL"
Hi
Error OL means that the washer has sensed an overload (OL) condition. It can also be a false error code appearing due to faulty lid switch. Sometimes this error code appears when lid is not closed/opened properly. You can check the lid switch for any disconnections, if the connection to lid switch is fine then use a multimeter to check the continuity of the lid switch. If the lid switch is fine then there is a piece of clothing stuck between inner basket and the outer tub. Disconnect the washer from the power outlet and then try moving the drum with your hand and check if it turns freely or is offering any resistance. If it is not moving freely then it is due to rusted drive shaft or motor. Hope this helps... Please post back if you need more assistance.
Daniel
Washer is skiping rinse and don't spin has code ol
Top Maytag Washing Machines Experts
Ronny Bennett Sr.
Ronny Bennett Sr.
ZJ Limited
ZJ Limited
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
