All lights are flashing on the control panel, dump valve for ice cycling non-stop.There is no water coming out.I checked the water line going to the fridge-there is pressure but there is no water coming from quick-disconnect on the top of the door.I changed the filter, empted the ice-maker, tried to disconnect the power.Also seesms to me, that the freezer is working but fridge is not.
Kenmore 77532 french door bottom freezer flashing lights and flapping ice door...jammed the door open on the ice dispenser and pulled fridge out away from wall, while I typed this suddenly came back to normal. Maybe it was too hot. It is late so maybe I will remove small access panel in morning and hope it was just an overheating problem
more developments on the Kenmore 77532...pushed a bottom an it started all over again.
I have put an electronic meat thermometer in the freezer and seem to remain at -1C
Bought the HV control board will try it...but first I will try to reprogram the suspected faulty board from the instructions given with the new board part number 12920710 $180
Here's a board on ebay cheap.
http://cgi.ebay.ca/Maytag-Amana-ICE2O-H-...
Instructions included.are reasonable to follow,
I just bought it from Sears parts center $180. Took me 1/2 hour to replace and program
Contact me if you need help
[email protected]
I replaced my board which I bought from Sears parts outlet. It came with instructions for programming using the front panel bottoms. No problem again for last 3 years
This sounds like the Maytag bottom mount that has a High Voltage Control Board problem. Does this have the freezer/fridge temp. display/controls on the left hand fridge door? Whats the model number and on the manufacture tag does it something on it like Code:0304 maybe? Let me know I may have an answer I do work on these for a living.
This is Kenmore 25" Bottom Freezer Refrigerator. Model number 596.77532600. I has freezer/fridge temp. display/controls on the left hand fridge door.
kenmoore model 76523 , ss bottom freezer. this unit is about 2 years old. suddenly the refrigerator completely stopped cooling but the freezer is fine, the lights work correctly but the digital display does not change temp control on any settings. I disconnected the power for an hour, i was then able to change all control settings but the refrigerator still not working. then after an hour the controls would not adjust anymore only display numbers and temp. would alarm .note; the freezer works but unable to adjust freezer controler. temp. did show as freezer cooling.all coils are frost free and clean.
any suggestions?
Same problem same model 77532 12 months old
I just started to have the same problem on my fridge 596.77533600.........What did you do to fix the problem???
Look forward to your help....
Having same problem with flashing lights on control panel & dump valve for ice/water dispenser flapping open/shut! Problem rectifies itself temporarily, BUT then starts after a few moments again..seems to be when motor is running to cool the fridge.
Please provide any help, as we are located in rural Canada & so will wait a while for a tech!
I have the White Model of this Refrigerator PN 596.77532600. Lights flashing erratically and disconnecting power not the answer. Removed the front panel on the left hand side and removed the three wire connector feeding into the right hand side of the opening. I believe that this control wiring goes back up inside to the ice maker. After applying power, the door for the ice stopped opening/closing, the flashing lights stopped and the fridge appears to be working, staying cool in the fridge and frozen in the lower section. Turned the ice maker switch off, removed the ice from the ice tray and will try to hook up the three wire connector tomorrow to see if problem is related the ice jam or water pressure / water frozen in the line / water inlet issue.
DISPLAT LIGHTS KEEP FLASHING, NO WATER OR ICE AND FRIDGE IS NOT COOLING
