39L1350U) and am trying to hook up the DVD player. ... My DVD player only plays in black and white ... My DVD player is an old Sony. .... Was using and S-Video connecting cable to the TV. ... suggested to use VIDEO instead of COLOR STREAM, I changed that in the TV menu, plug the red and while at the back of TV where ...
Jul 14, 2014 - I hooked up my DVD player and I have no color. ... you need to use the connections on the left side of the TV or on connections on the back. .... is turned on, which can cause this black and white image issue you're having. ... If the Player shows correctly on a different TV with the same hook up, and different ...
try using a different input on your tv. If possible try using a different cord to hook the dvd player to the TV. If neither solution works it sounds like a faulty dvd player.
also try using a different source on the tv like another dvd player, cable etc. etc. hopefully on the same input to make sure the tv is working properly .
Allot depends on your DVD player and WII. Since the TV is a color one unless the movie your watching on the DVD player is B/W it will play in color, same with the WII. If your DVD player supports HDMI then select one of the HDMI ports on the TV (there are 3) same for the WII depending on what outputs it supports select one of the corresponding inputs on your TV. The user manual shows several options for various components and should be of some assistance in your connections.
2. If they are correct, take out movie, press Play/Stop at same time on the front of the unit (not remote) to reset any settings that may have been changed.
I too had the same problem. On the Vzio there are AV plug ins on the left side (not the back, but the left side). Use these jacks when connecting to the DVD player and choose the AV button on the TV remote. Viola!
If you are using the s-video jack to connect the DVD to the TV, the jack could be loose or the wire could be bad. The s-video cable has 2 signals, the black-and-white (luminance) and the color (chroma). If the chroma signal is not getting through, the picture will be in black and white.
