When i plug my camera into the usb port on my computer it says the usb device attached to this computer has malfunctioned and windows doesn't recognize it.
Try NOT connecting your camera to your computer.
The best way to download pictures from your camera to your computer involves removing the memory card from the camera and plugging it into a card reader (either built-in to the computer or connected via USB or FireWire). This is likely to be faster than connecting the camera to the computer, and won't run down your camera's batteries.
Once the card is plugged in, it will appear to your computer as a removable drive. You can use the operating system's drag&drop facility to copy pictures from the card to the computer's hard drive, the same way you copy any other files. Or you can use any photo cataloging program such as Picasa.
SOURCE: USB DEVICE NOT RECOGNIZED KODAK EASYSHARE C913
remove you memory card
turn camera ON > Press Menu > go to setup menu> format internal memory>
take 1-2 picture > reconnect your camera to the computer>
if the camera will be recognized> reinsert the MMC> format the MMC > it will delete all your pictures including the corrupted ones
most of the time its just a MMC issue
good luck
