Hi, enter 10871087 on keyboard of machine, then enter 163.After that press "execute" and start button.machine will restart and will be ready to copy.Otherwise,call service.
BR
MY MACHINE IS MODEL km- 1635 IT HAVE A ERROR C-6000 ,HOW CAN FIX IT
Thank you so much BR! best solution indeed!
MY MACHINE IS MODEL IR-3530 IT HAVE A ERROR C-6000 ,HOW CAN FIX IT
Code Error name/description
E000 fixing overheating
E001 fixing assembly overheating
E002 fixing assembly low temperature
E003 post-standby fixing low temperature
E007 fixing film rotation error
E010 main motor rotation error
E014 fixing motor rotation error
E019 waste toner case full, waste toner case full sensor error
E020 toner clogging between sub hopper and developing assembly
E024 developing assembly connector disconnection
E025 hopper motor, bottle motor error
E032 NE controller counter error
E064 power supply voltage error (high-voltage)
E100 BD interval error
E110 scanner motor error
E191 communication error for high voltage power supply
E202 CIS home position detection error
E225 CIS light intensity error
E227 reader unit power supply error
E248 backup memory error
E261 zero-cross signal error
E315 image data error
E400 feeder communication error
Dear Sirs.
Thank you very much.
have a nice day.
I'm sorry .where are you from.
I introdue my self ,my name is Hung, I'm from vietnamese.
sorry ,what do you know about VIETNAM ?.
I'm very grateful for having worked with a great person like you.
I will miss you all.
GOOD LUCK TO YOU.
Mr.Hung(from vietnamese)01/28/08.
I have the copier machine Sharp AR-5127 ,the error code U240 appears and coping cannot be done.What can be done about this ? is there a code that can be used to correct this?
pls you help me.
thank you very much.
c 6000 is a type of Fuser error,
may have either a blown lamp, blown thermo fuse or faulty thermistors, but more then likely a combination of at least two.
try the reset as suggested by 'kemo', however it is best to get the machine checked as they do not normally just bring up these codes for no reason. I would suggest that if resetting the code fixes it then it is more then likely either faulty/dirty thermistors.
