GE 30 in. Profile JGP933 Gas Cooktop Logo
Posted on Dec 25, 2009
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Electric starter won't stop clicking - how to unplug starter?
We cleaned stove top and now the electric starter won't stop clicking. No sure what to do?
Not sure how to unplug the electric starter, but see report that did that:
* and wiped up the water,
* took off burners, etc., and
* placed a fan over the stove.
* After about 3 hours, I plugged in starter and the clicking is no longer.
Anonymous
Level 3:
  • GE Master 3,361 Answers
  • Posted on Dec 25, 2009
Anonymous
GE Master
Level 3:
Answers
3361
Questions
Helped
1028985
Points
10654
Your electric spark switches got wet. You may be able to remove the knobs and use a hair dryer through the switch/valve opening to dry them out.
Older kenmore electric stove
You could try to restart and stop clean cycle. Otherwise unplug stove and remove back panel to access locking mechanism.
3helpful
2answers
Constant clicking from electric pilot connection. won't stop after leaving for long time, unplugging overnight, cleaning all burners, running gas by lighting with match and letting the flame run. ...
Hi nancypp,
The ignition switches probably got wet.
Please follow my below Tip on how to fix it:
GAS STOVE CLICKING PROBLEM...
Kind Regards
JEDEMEYER1
* If this solution helped you, please accept it
My Jenn Air Electric stove is making a clicking noise. When I put my hand on one of the cook top knobs I can actually feel a vibration when the click occurs. What is this?
Gas stove? LP? It is probably the electric spark ignitor. Many times when you clean the stove top water from the sponge gets below. The water droplets (align mysteriously) make the connection between the wires, and the stove thinks it's supposed to be igniting. When the water evaporates, the switch will work fine again & the clicking should only occur when igniting & then backed off.
This happened to me once before.
Ignitors clicking
Electric gas igniters sometimes get stuck in one position causing a clicking sound. The clicking sound that you hear is the electric arc that is pulsing from the igniter conductor (wire) to ground (the gas burner). It receives power from the electrical outlet that the stove is plugged into.
Residue from food and sometimes cleaning products may be preventing the igniter from producing a spark (Arc) to the base of the burner. This is a common problem that occurs when the stove has been cleaned or food is allowed to build up. Make sure that the igniter and the burner base are clean and dry. This will help with proper operation. Oven cleaner and a small tooth brush may be used to accomplish this. Another problem with ignition may occur if you have too little (touching) or too much space between the igniter and the base of the burner; it will prevent the burner from igniting. You should only have a little more space than the thickness of a nickel between the burner base and the igniter. A good “blue” arc from the igniter to the burner base is optimal. If this doesn’t work, you may need to replace the electric igniter module. Good luck.
3helpful
The electric starter on my stove top will not stop clicking after I spilled water on it
Need to dry it out. The water is conducting a smalll amount of electric to the igniters causing them to click. You can either turn the burners on for while to do this or use a hair dryer. hope this helps.
Jan 29, 2010 • Cooktops
Clicking after cleaning
sounds like the electric starter is too far from the burner and isnt sparking any more
Electric starters keep firing after I sprayed cleaner
your spark modual got shorted with the liquid you sprayed in there or spilled you can try unplugging it overnight to let it dry. at least 24 hours or you can take the cooktop of and get a hairdryer and dry out the spark modual.or if you wait 24 hours - 3 days and still not dried out you need to replace your spark modual but more than likley give it time it will fix itself.
2helpful
Stove top ignition doesn't stop ticking
My Dacor cooktop had a similar problem of continuously clicking igniters. I unplugged it a couple months ago and used a piezoelectric igniter to get it started. Then I looked in the Dacor FAQ and it said to clean the ceramic igniter posts with alcohol not water. I had to scrape some gunk off a couple of the posts with a knife before cleaning with alcohol. Now it works.'
I think the igniters use electrical conductivity to detect when they need to spark, so even slight invisible contamination on the igniter insulator can confuse the sensing system. Also they all seem to fire as a group, so all of them need to be clean because if any one of them is dirty then they will all malfunction.
4helpful
Spark igniter discharging when turned off
Hi
It sounds like somebody clean up the stove and the electric sending unid is wet, try this: the knob that correspond to the ingniter that it's clicking nonestop, take the knob out and you will see the sending unit, pull it out unplug it and dry it out and then try it again, it should work properly after it's dry.
Eddie Rentas
Tupper Lake NY
Thermadore Stove Top Ignitors Won't Stop Clicking in the OFF POSITION
Needs to be serviced. The electronics for the igniter section has gone bad.
Top GE Cooktops Experts
ZJ Limited
ZJ Limited
Paul Carew
Are you a GE Cooktop Expert? Answer questions, earn points and help others
