They're very easy to open. You can pull the outer pads off by squeezing them at the bottom edge.
Inside, you can prize the speaker plate off the white plastic body with your fingers, and access the connectors if you need to.
The headphones all just clip back together.
Mine just stopped working in the right ear. I fixed them in about five minutes.
THANKYOU SO MUCH! just fixed my 11 year old cans with the help of this page! :D
pry the white cap from the black from the narrow bottom end (end where the cable attaches) and it pops off.
I'd lost my left ear (again!) turns out it's just a loose connector. fixed in 5 mins
Sorry guys i am sorry but i don't understand the stuff to do. Can you explain the process precisely? Thank you.
Yea, when u said connector i didnt quite understand, but figured it out. The cable that gues into the "loudspeaker" splits out in two cables. At the end of theese cables they each have a "leg" like a wall-plug has two legs. Just push the legs down towards the speakers carefully, and fixed.
My bet would be to remove the pads and foam and you will probably find access screws. If the foam doesn't want to come off force it! You can allways glue it back on afterwards.
