Panasonic PV-GS35 Mini DV Digital Camcorder Logo
Posted on Dec 25, 2009
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
The lcd screen has stoped working om my panasonic pv-gs35. the veiw finder still works. is there a mode i changed or any idea whats wrong...thanks, kyle
Anasty B.
Level 2:
  • Expert 126 Answers
  • Posted on Dec 30, 2009
 Anasty B.
Expert
Level 2:
Answers
126
Questions
0
Helped
39402
Points
169
HELLO! IF YOU MOVE THE LCD SCREEN BACK AND FORTH AND YOU SEE PICTURE FOR A SECOND THEN LCD HINGE MUST BE REPLACED,IF NO PICTURE AT ALL MAYBE PROBLEM ON LCD BOARD.
1helpful
Does my Panasonic PV-GS35 Mini DV Digital Camcorder have a VCR mode and how do I access it? I am trying to copy a VHS tape to mini DV and I cannot get my camera to do it.
The Panasonic PV-GS35 will let you record digital media to the mini DV cassette if the other video source has a DV input/output connection. Then you use the 4-pin to 4-pin Firewire DV cable, PV-DDC9 . This cable is available from Amazon, https://www.amazon.com/LETO-FireWire-Panasonic-Camcorder-PV-DDC9/dp/B00MLQVMSK , and other vendors. The digital camera doesn't have the S-video input needed to record from most other sources.
For information on the digital dubbing feature, see the manual starting on page 42. Panasonic has the manual on the product support page: https://shop.panasonic.com/support-only/PV-GS35.html . The current link to the manual is ftp://ftp.panasonic.com/camcorder/om/pv-gs19_en_om.pdf . See page 13 of the manual for the location of the DV port.
I hope this helps.
2helpful
Pv-gs35 sdhc formatting win7
SD cards go up to 2GB in size. SDHC cards go from 4GB to 32GB.
The PV-GS35 works with SD cards, not with SDHC cards. Your 1GB and 2GB cards are SD cards. Your new 16GB card is an SDHC card. While SDHC cards fit into the slot, they are electronically incompatible and will not work in devices not designed for them.
Describe your Panasonic PV-GS35 Mini DV Digital Camcorder Problem: When I turn the camcorder on in the video camera mode the lcd panel and th evf show black, it does not show current picture to record. All...
There was an earlier post that explained the black ribbon between the LCD viewfinder and the body of the camera is split. You would have to buy a new LCD viewfinder for about $90 or send it back to them to fix for around $250. The same thing happened to my camera and I can actually is the split. If you close it down more than half way the picture shows up. I called Panasonic and they said you have to buy the whole LCD, that you can't just buy the ribbon. They don't even have a part number for just the ribbon. Good luck.
I have a Panasonic pv-gs35 Camcorder when I open the lcd monitor the screen turns all white. The viewfinder works ok. Should I have to replace The lcd monitor?
first check the LCD connection, try to reconnect the flexible cables on the LCD board,
second, replace the flexible cable goes throungh hinge.
if those won't work, you may need to replace the LCD or main board.
Panasonic GS35
i suggest you insert a head cleaning casette to see if this removes the lines.the lines occur when one of the heads is dirty or not operating. if this does not solve the fault then the head might need changing.
Audio
You can connect multimedia speakers, try your PC speaker.
It will work.
Panasonic PV-GS35 Viewfinder screen connection problem in hinge joint
the hinge is definetly damaged and is going to need replacing. these hinges do need replacing if used allot because this is a moving mechanical part. This is not a easy thing to do, it needs to be done by a panasonic technician.
PV GS 35 wont play tapes from other cameras
perhaps it has to do with the SP and LP settings, I know certain video editing programs won't capture video recored in LP.
Top Panasonic Video Cameras Experts
NOEL
NOEL
Are you a Panasonic Video Camera Expert? Answer questions, earn points and help others
