Question about Phase Linear UDV9010 Car DVD Player
My phase linear uv7i can't plays dvd's or cd's and the screen is totally blue
When i put a cd or dvd in my phase linear uv7i in the display says loading all the time and the display light is off. when i open the the escreen is totally blue and i don't see the menu, the only thing that works is the radio, i checked all the connections and they are good.....please help me......thanks
  • 3 more comments
  • Anonymous May 13, 2008
    I have same model and same problem, phase linear uv7i, completely blue screen showing clock time in botom right corner only, not reading dvds, saying loading all the time, any solutions yet? my email is gjubreto@hotmail.com, if anyone can help will be greatly apritiated, thanks in advance.
  • mtc212001 Sep 24, 2008
    yea mine is doing the same thing. when i put a cd in my player it keep sayin bad disc and wont read. when i put a dvd in there it will play it. so whats the problem
  • Anonymous Dec 15, 2008
    i have the same problem the radio works but the screen is blank and now it is stuck open
  • Anonymous Mar 16, 2009
    Hooked up to E brake and blue screen saying needs to be hooked to E bnrake
  • mrpresident7 Mar 28, 2009
    i cant hear any sound but the video is playing frm the dvd, even after bypassing it.
Caution it´s unlawful to operate a vehicle while video is dispayed in thr drivers viewing area
engage emergency brake sequence to enjoy video???? help help please
Posted on Sep 18, 2008
    New Friend:
The way I bypassed mine is simple. I installed a toggle switch, on one side I hooked up the pink wire, on the other, I hooked to the ground. Now when blue screen pops up, I simply turn off switch for 5 seconds and turn back on and it works. You have to do this each time you watch a movie and sometimes I have to do it twice if the timing isn't right. I also am not responsible for any accidents, tickets or stupidity that takes affect as a result of you watching a movie while driving.
Posted on Oct 19, 2012
There are two ways of doing this:
Insert the DVD
After the disc loads and plays you will see a blue screen telling you "it is unlawful to drive with a movie blah blah blah"
1)Activate the brake sequence and disable the blue screen using the hand brake, the switch method or anything else to give the unit its three pulses to disable that freakin blue screen.
(What I did was I installed my radio entirely, then took the pink wire and touched for two seconds, removed for two seconds and then touched and held the negative pole of a mower battery laying on my passenger seat until the screen was no longer blue.)
2) Next, on the main remote press stop twice, then 1, 2, 6, 4.
You will now see a hidden menu that says:
Region Code
Brake Override (I know you're drooling by now)
Macrovision (Watch all the burned and pirated movies you want if this option is off)
Loader Version
Model Version
3) Using the right joystick on the unit, navigate to the options of your choice, click on them to toggle on, off or which region code you want.
This is what you want:
Region Code: 1
Brake Override ON
Macrovision: OFF
When your done, click SYS SETUP on the main remote TWICE to save the settings and bingo, your done!!! Hooray!!! You can now kill your whole family in the car while watching that adult movie while your driving.....
The other way of doing this is by not engaging the parking brake sequence, thus you're inputting the code blindly.
1) Insert the DVD and you'll get the blue screen.
(If you have more than one tv, the unit itself will have the blue screen but the additional tv's you have plugged in will NOT, they will show the dvd menu. Thus you will be able to see the hidden menu on the additional screens after inputting the code, but not on the main unit because of its blue screen.)
2) On the main remote, push stop twice and then 1, 2, 6, 4
3) Push the joystick on the unit SOUTH twice and then click it once.
4) Press SYS SETUP on the main remote twice to save your settings.
It may take a few tries but you'll get it. This method can be done if you don't want to bother temporarily activating the brake sequence, but if you only have the unit and no additional tv's, its #$%^&* damn hardbecause you can't see the settings your changing.
I tried to make this as clear as possible. If you have questions, private message me or post here.
Best of Luck!
By the way, this is for informational purposes only and I will not be responsible for anything bad/stupid/ignorant you do with your Jensen unit.
Posted on Jan 28, 2009
Really you dont have to hook up the pink wire. There is a bypass sequence already installed in the system to over ride the e brake...You have to put a dvd in.. Once the screen comes up that says you cant play this disc and engage e brake bla bla bla..Push down on the right stick twice...then push it in..a screen will come up saying E brake bypass on...then turn off your system and turn it back on and your good to go..
Posted on May 27, 2008
    New Friend:
So if you have remote this has work for me press stop 2x on remote 1264 arrow down press play press system setup this is for uv71 phase lineaner
Posted on Apr 23, 2016
    New Friend:
I Have The Same Model. Here is what you all need to do. In order to bypass the ebrake switches blue preventing screen you must take out the head unit and splice(tie in) the PINK park wire to the BLACK ground wire. Trust it works just fine after doing so, so you will not have to worry about the horrid blue screen no more. As for The Bad Disc problem, go to your neighborhood pharmacy store or radioshack or electronic store and purchase a DVD Disc Cleaner kit, it should do the trick due to it raising the success rate up to 45%, if not then i wish you all the best of luck.
Posted on Mar 20, 2010
HOW DO I CONNECT PARK SW IS THE PINK WIRE I CANT WATCH DVD I CAN LISTED TO CD BUT WEND I PUT I DVD IT LOADED IT AND THEN A BLUE SCREEN POP UP IS THEIR A WAY TO BYPAST?
Posted on Mar 26, 2008
    New Friend:
I pulled the radio out took that wire that had big sticker on it hook up to break.spliced it hooked it up to black wire.still didnt work.
Posted on Nov 08, 2010
  • 4 Answers
That sequence didnt work
Posted on Nov 25, 2008
I tried that and it didnt work???
Posted on Jun 24, 2008
  • Anonymous Apr 23, 2016
    so if you have remote this has work for me press stop 2x on remote 1264 arrow down press play press system setup this is for uv71 phase lineaner
6ya staff
SOURCE:
My Phase Linear UV7il accept only some CD's
the head unit is not reading due to incompatibility with thebrand or type of disck
Dec 29, 2009 | Car Audio & Video
How to assemble the phase UV7i dvd/cd player
can u give me some info about how to identify the power supply wire to a car cd player
Jun 27, 2009 | Phase Linear UDV9010 Car DVD Player
I have the phase linear UV7i I was trying to put in the overide
reset it,try with out the remote and change the remote battery,put in dvd wait for the blue screen,then press stop 2x then enter 1264 then,if you have a up,down,l/r control on the deck press down 1x then press play,you dont even have to use the ground wire then go to the rest, when you can see the menu,i dont know if it will work but u can give it a try
Jun 18, 2009 | Phase Linear UDV9010 Car DVD Player
How can i watch dvd while i drive?
its very sample. you will insert a DVD and everything will be start and going automaticly.
May 29, 2009 | Phase Linear UDV9010 Car DVD Player
Bad disk
Wow! That's a first. I used to sell both the Jensen AND Phase Linear versions and never a problem. It sounds like a bad unit. You say it plays NOTHING? No CD's OR DVD's that are the factor made?
The only thing I hav up my sleeve is to do a reset on the unit. If it has a button (I don't think it does frm what I remember) use it first, then with the unit ON, unplug the poer plug, wait a few, then plug back in and see.
Sorry I have no more tricks foir that,
Larry T
Winona Lake, IN
http://www.cybersoundsaudio.com/cybersounds/vehiclepics.html
Jan 26, 2009 | Jensen VM9510 Car DVD Player
Phase linear UV7I
I Need Phase Linear uv7i Owners Man. Also Vol. Control Goes Up As You Turn It Down. Repairs??? C/D Dvd Not Working! Help!
May 27, 2008 | Car Audio & Video
Phase linear uv7i
RUN A TOGGLE SWITCH FROM THE PINK WIRE AND THE OTHER END GROUND IT PUT DVD IN FLIP SWITCH 2OR3 TIMES YOU SHOULD BE ALL GOOD
Dec 28, 2007 | Alpine CDA 7893 CD Player
Phase linear UV7i makeing the dvd player without useing parking
There is a pink wire that goes to the parking brake. It connects to the ground wire on the parking brake that makes the brake light come on the instrument panel.
connect the pink wire on your stereo to a frame ground.
Oct 28, 2007 | Car Audio & Video
Phase Linear UDV9010 Car DVD Player Logo
3,431 people viewed this question
Top Phase Linear Car Audio & Video Experts
Marvin
Marvin
Mark Skinner
Are you a Phase Linear Car Audio and Video Expert? Answer questions, earn points and help others
