Question about Sony DAV-S300 System
Why can't I hear audio from my TV on the DAV-S300's speakers?
    New Friend:
  • 74 Answers
Does your tv have (audio output) rca connectors? becouse they usually have audio inputs, if yount thats your problem
Posted on Dec 26, 2009
Testimonial: "Thx."
6ya staff
SOURCE:
I need to find speaker connectors for Sony DAV S300
Check eBay "sony DAV-S300" check the 'include description' box. Several there.
Jul 16, 2011 | Sony DAV-S300 System
Is there audio digital out /in on dav-s300
There is a single optical digital audio input, no digital audio output.
Feb 27, 2010 | Sony DAV-S300 System
Can the dav s300 speakers be set up without plugs?
Yes, they can. The lead with the color band is +
Feb 07, 2010 | Sony DAV-S300 System
CAN I HOOK THIS UP TO HD TV FEED WITH A PVR
henknm
If your PVR has an Optical Output then you will be able to hook that to your SONY DAV-S300. If it does not you will just be able to use the standard analog stereo connections. I included a picture of the Optical port on your SONY DAV-S300.
Issken
Jan 18, 2010 | Sony DAV-S300 System
I received an I-HD901 surround system. How do I hook it up directly to my Sony tv and do I need to buy a receiver or an amplifier?
DON'T NEED A SEPERATE AMP THE SYSTEM HAS ONE IT IS PART OF THE CABINET THE DVD PLAYER IS IN, YOU CAN HOOK IT TO THE TV WITH A HDMI CABLE OR STANDARD VIDEO CABLE OR A PROGRESSIVE SCAN CABLE SETUP, FOR AUDIO U CAN USE STANDARD RCA CABLES, OR DIGITAL AUDIO, CHECK TO TO SEE WHAT OUTPUTS AND INPUTS THE TV G THE TV HAS ALSO CONSULT YOUR USER MANUAL FOR THE SURROUND SOUND. HERE ARE THE SPECS FOR THIS SYSTEM.
1000 WATT system total program power
5.1 Cube cinema HTS, 12 active drivers/magnetically shielded
I-Cube design satellite system
4 Multi-directional 2-way speakers()
center channel has 2-way with horn tweeter enclosure (200 WATTS)
Dual sub-woofers 400 WATTS; 2X6.5" aluminum poly-laminate cone
linked through digital custom crossover circuitry finished in: high-gloss piano and composite black w/silver brushed aluminum
complete 6 piece system (HTS surround speakers
Jan 08, 2010 | Sony DAV-S300 System
Sony DAV-S300 volume is unchangeable from either remote or knob. Any ideas?
Is the sound coming from the speakers you have installed, or from the speakers on the TV itself?
Dec 19, 2009 | Sony DAV-S300 System
My dvd player (Sony dav s500 system) kept freezing and now always says"disc is dirty" and wont play. Can I connect another dvd player to the system? How would I connect the 6 speaker cables into the new...
Umm, this isn't just a DVD player, It.s an amplifyer too. Just leave the speaker cables alone, plug in the new dvd player into the "video2" jack, yellow cable onlt. Then,plug the audio cables into the video2 jacs (the red and white ones). Select "video2" on the SonyDAVS300 and "video2" on the tv. Insert the dvd into the new player and enjoy. It's screwy but it works through the amp and sends the picture to the tv.
Jan 02, 2009 | Sony DAV-S300 System
COULD YOU TELL ME IF IT IS POSSIBLE TO CONNECT MY DAV-S500 SYSTEM TO A SONY BLU-RAY A BDP-S300 SO THAT I CAN USE IT FOR THE SURROUND SPEAKERS
you need to go into the settings on the bluray player and go into the audio settings and change the sound output to dts
Oct 15, 2008 | Sony DAV-S500 System
Audio problems
Have you tried playing around with the Audio after pressing DVD Display? May be your answer.
Jul 05, 2007 | Sony DAV-S300 System
Sony DAV-S300 System Logo
274 people viewed this question
Top Sony Audio Players & Recorders Experts
 Grubhead
Grubhead
Ekse
Are you a Sony Audio Player and Recorder Expert? Answer questions, earn points and help others
