Question about HP f1905 19" Flat Panel LCD Monitor
Small colored square on 2 tvs, is it the satellite dish?
    President:
  • 3,085 Answers
Turn off closed-captioning
Posted on Jan 04, 2010
    Sergeant:
    Champion:
  • 318 Answers
You have to disconnect all the cables, and let signals start coming from the dvd to tv, if that works without the square colour.
later start connecting one by one to the tv, this way you are able to troubleshoot a cause.
okay
6ya staff
SOURCE:
How do I change one remote so It doesn't run both TVS
Dish Network TV 2 Duo tuner fix Dish 722 (877) 576-7100 ...
? 9:54
https://www.youtube.com/watch?v=e5154_wVkcc
Apr 7, 2014 - Uploaded by SilverStar Satellite Dish Network Retailer
On my tv 1 I keep changing it and it changes on TV 2 too so weboth watching .... My tv2 remote doesn't work for tv2 and whatever is being watched on ... To mirror tv 2 run a splitter offthe tv2 side of the diplexer as many as you ...
Jan 12, 2016 | Vizio Televison & Video
I have to TVS How do I change one remote so it doesn't run both TVS
Multiple Boxes, same room, remote changes ALL TVs - Comcast Help ...
forums.xfinity.com/t5/XfinityTV...remote-changes...TVs/td.../1441397
Oct 13, 2012 - I have 1 DVR box and 2 small boxes for a 3 TV setup in my living room. ... to have each remote only change channels for the box it's associated with? ... Nope,both the DTA's and the newer RNG & DCX boxes use the same IR codes. ..... Thatdoesn't help anyone who has multiple tvs in the same room and ...
? 9:54
On my tv 1 I keep changing it and it changes on TV 2 too so weboth watching .... My tv2 remote doesn't ...
FAQ's ' seiki
Jan 12, 2016 | Televison & Video
How do I hook up my satilite dish to our motor home?
Most TVs don't have a built-in satellite receiver. You'll need to buy and install a suitable satellite receiver box for the signals that your dish is capable of receiving. The dish connects to the satellite receiver. Then the sat receiver connects to the TV via either AV cables or HDMI. Hope this helps.
Sep 16, 2014 | Televison & Video
Splitting a satellite signal to 2 tvs
Do you want to use a separate satellite receiver on each tv or just want to send the picture from one receiver to two tv's? It makes a huge difference. If you do it wrong you can damage both the satellite receiver and the tv, so be careful. Using separate receivers requires a multi switch near the dish. This is necessary because the satellite receiver sends a voltage up to the dish to operate the elecrtonics there. That voltage will damage the dish without that multi switch installed. an ordinary splitter will get the picture from one receiver to two or more tv's as long as the cable length is not too long.
Dec 29, 2013 | Televison & Video
How can I move a receiver to another room that has . For example, downstairs i have my two receivers with 1 DVR that controls 2 TVs the one downstairsTV#1, and 1 upstairs TV#2. The other dish, controls TV...
Hey there! Becki Barned from Dish Network customer service here!!! If you want to do this! You would need a tech to come out and install the DVRs in the new rooms. If you try to move the reveivers, you will only get an Acquiring Satellite Signal message. If this has not been resolved, you can find us on Twitter, or blog back!
Nov 28, 2010 | DISH Network 311 2-Room System DTV...
Unhooked all lines in back of tv cant remember to rehook up have2
granmabj,
There are common connections to each receiver but there are unique connections also depending on the receiver. Solo receivers have a coax cable coming from the Dish outside connected to Satellite In. Duo receivers and DVR HD receivers have the coax cable that comes from the dish outside that connects to Satellite 1 and Satellite 2 using a splitter. There is also a cable (coax, RCA (yellow, white, red) or component (green, blue, red - video, white, red - audio) or an HDMI if HD) connected from the receiver to the TV 1. For a duo receiver TV 2 may be backfed on the cable coming from the dish outside using diplexers. This may sound confusing but you can call 1-800-333-3474 for assistance.
Ray Calo
DISH Network
Jul 23, 2010 | DISH Network DVR-625 DTV Receiver /...
After programming my NEW Harmony One Logitech remote I can't get it to change channels on the Dish HDTV DVR along with a bunch of other problems.
To control a Dish Network PVR/Satellite, it needs to be set to respond to the default Remote Address (1).
To reset your Dish Network PVR/Satellite to the default Remote Address:
1. Press SYSTEM INFO on the receiver's front panel. The System Information screen displays on the nearby TV and shows the Remote Address.
2. Using the original Dish Network remote, press and hold SAT on your remote control for about three seconds, until all of the mode buttons light up, and then release SAT.
3. Using the NUMBER PAD, press the 1 button
4. Press POUND (#). If you entered the address correctly, SAT will flash three times.
5. Press RECORD. Make sure the Remote Address you see on the System Information screen is 1.
6. Press the SELECT button on the front panel to close the System Information screen.
7. Your Harmony remote should now control your Dish Network PVR/Satellite box
NOTE: Dish Network PVR/Satellite receivers sometimes have two tuners, allowing them to be used in more than one room on different TVs. Harmony remotes can only control a Dish Network receiver's main tuner while still in the same room with direct line of sight to the device.
What other issues are you having with the remote?
Dec 25, 2009 | Logitech Harmony One Advanced Universal...
It wont display satellite(dish) or
If the satellite picture displays on other tvs in the house, and you have the satellite hooked up to the rear projection tv you may have to do the following:
1. Using the remote, select the input button. You will now see a menu of several choices.
2.Methodically go from one to the next until your satellite pix appears.
Nov 14, 2009 | Sony Grand WEGA KDF-50WE655 50" Rear...
Splitting satellite signal
standard spitter can be used for regular TVs. If the signal degrades, it can be boosted with an distribution amp, and could go to 100 TVs on channel 3 (for instance).
Jan 04, 2009 | Garmin KVH TV/SAT Switch SATELLITE...
Lost satellite signal after hooking up an hdtv
Provided you did not make any changes to the cabling through out the house there is no reason that you would have lost satellite signal except if something is in front of the dish, some one moved the dish e.g. child bumping into it if it is on a pole, or there is a major storm in your area e.g. blizzard, hurricane etc. You also may have snow build up that may have caused this issue or a form of wildlife that has decided to use the dish as a perch and is blocking the LNB's. The most likely result would be trying to split a signal that is coming from the dish going to another satellite receiver or the multi-switch. There are a few ways to get a signal to that TV.
1. RESTORE THE SYSTEM TO ITS ORIGINAL CONFIGURATION.
2. Either come off the multi-switch in the attic or outside the home and run new lines to the new receiver if you have one for this TV.
3. You can run new lines from the dish to the new TV if your system has an available port(s).
4. This is the least preferred by most homeowners as it will result in two tvs viewing the same programming- You can put a splitter into the line going from a receiver to the tv and run one of the out ports to the new tv and the other back to the original tv.
I hope this assists you and thanks for using Fix Ya. If I can be of further assistance please let me know.
Jim
Nov 10, 2008 | Emerson EWL20S5 20 in. EDTV-Ready LCD...
HP f1905 19" Flat Panel LCD Monitor Logo
Top HP Computers & Internet Experts
Ekse
Thomas F. Schneider
Alun Cox
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
