Uniden Cordless Phone Logo
Anonymous Posted on Jan 27, 2008
Cannot have 2 phones in use at the same time 25952
If someone calls and then I say pick up to another person they can't do that. I says ready, talk, then unavailable. Do you know how to fix this? Is it fixable or do I need to take it back?
Help!
Thanks
Ann
  • Anonymous Jan 27, 2008
    These phones were made for "privacy" so no one can pick up another phone and listen to your conversation - must have been created by a very paranoid person. I will be returning mine.
    Ann
    I forgot to say this phone is a 25952 5.8 GHz that I am returning
martin hogg
Level 2:
Scholar:
  • Expert 157 Answers
  • Posted on Jan 29, 2008
martin hogg
Expert
Level 2:
Scholar:
Answers
157
Questions
0
Helped
76446
Points
263
Here is a selection from the manual and a link to the full manual to download.....it should help.
http://www.home-electronics.net/ge/pc/IB/25952EE2_IB.pdf
Transfer ON/OFF
In order to use the Call Transfer feature (applicable ONLY with additional handsets), you must have the Transfer ON/OFF set to ON through the menu of the transferring handset.
1. Press the mute/menu button until TRANSFER 41OFFshows in the display.
2. Use the CALLER ID-VOLUME (5or6) button or the touch tone pad on the handset and select 2ON.
3. Press mute/menu again to save.
Default Setting
You may return handset settings to the factory default setup using this menu.
1. Press the mute/menu button until DEFAULT 4NO shows in the display. NO is the default.
2. Use the CALLER ID-VOLUME (5or6) button on the handset to scroll to YES or NO.
NOTE: If you choose YES, all settings in the programmable menu return to the factory defaults.
2helpful
How to make a conference call in nokis n 72
  1. 1ST OF ALL, LETS SAY YOU WANT TO TALK TO THREE PEOPLE AT THE SAME TIME.
  2. CALL THE FIRST PERSON,WHEN THE PERSON PICKS UP THE CALL, PUT THE PERSON ON HOLD.
  3. DO THE SAME THING FOR THE REMAINING TWO OTHER PEOPLE
  4. THEN PRESS THE LEFT OPTION BUTTON
  5. SCROLL THROUGH AND FIND THE ACTIVATE THE 'CONFERENCE CALL' ACTION
1helpful
Is it possible to do 3 way calling with the Panasonic KX TG6071B
Not unless the phone as 2 lines but u have to call the both people or the person you called can but it go's both ways you just have to press the talk button then call someone then press talk again then call that person then press talk again and you all three should be on the same line
1helpful
The phone rings,states the number calling but you can't talk to the caller. When you answer the phone, the person on the other end can hear you, but you can't hear anything. You can't get a dial tone when...
The switch that the handpiece activates is not working. Could be optical, magnetic or physical. It may need cleaning, adjusting or a wire connection repaired. Also check the curly cord and its connections between the handpiece and telephone.
The Intercomm Turns on by itself
There is nothing wrong with your phone. The person or persons calling you are doing a voice call.
Voice call basically pages the phone, to talk to you.
If you want to diasble this, you would need to take that button off the phones. There are other ways, but they involve more programming.
Lg tg800f (callwaiting)
hello shaziniaz how to use your call waiting function is when you are on a call or when you are talking to someone on your phone there will be a beeping sound in your ear just tell the person you are talking with to hold on, and must look if the a call coming in you will see hold and answer you put the person on hold and then press answer and talk with person and call waiting after you finish you press back hold and talk back to the person you was talking with before. thank have a lovely day
2answers
1helpful
3answers
Does not ring
is the ringer on the base or phone on? check that first.if that's ok, then plug a regular corded phone into the phone jack and see if there is dial tone.if there isn't any, try other jacks in the house. if still not working, call your phone company.
wg
Omega 2000
If you mean you want to have someone on each of your extensions listening to the same conversation, it can not happen. The reason for this is the first phone to pick up makes a connection with the base. The other phone will not be able to make that same connection as long as the first one is still on.
3answers
Audio Feedthrough
wow, no one has posted a response for this poor sap. I don't know what to do, but someone should at least post some insight!
Personally, I think it may be a power issue, as possibly the current going to the phone is not stable, so it is interfering with the machine's abilities to listen for someone else picking up on the other end.
1helpful
5answers
GE 25952 5.8 GHz
I just called GE/Thomson tech support (1-800-720-2094). GE cordless phones do not allow users to pick up an additional extension so that two people in the house can speak with a caller. He explained that it was for privacy.
I will be taking back my system today. :(
Top Uniden Lands Phones Experts
k24674
Grand Canyon Tech
Grand Canyon Tech
Are you an Uniden Lands Phone Expert? Answer questions, earn points and help others
