Tablets & eReaders Logo
Posted on Dec 26, 2009
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Everytime i turn on my computer it ask me for a password I enter the right password and it tells me that is incorrect. I continuosly enter it and it tell me is incorrect. i try to do a reset password but it tell me i need a disk or usb . can you help me
Anonymous
Level 3:
Brigadier General:
  • Master 10,406 Answers
  • Posted on Dec 26, 2009
Anonymous
Master
Level 3:
Brigadier General:
Answers
10406
Questions
Helped
2557545
Points
31058
Be sure that CAPS LOCK is not turned on.
Be sure that you have not used LEFT-SHIFT-and-CTRL to select a different input language (such as French).
Reboot, and press F8 to get a menu. Choose "Safe Mode".
You should be able to reset the password.
How to lock iPad
https://www.techwalla.com/articles/how-to-lock-an-ipad
Locking your iPad requires entering a four-digit pin every time you turn on your device.
Step 1
Select the "Settings" icon from the home screen.
Step 2
Tap the "General" tab on the left side of the screen.
Step 3
Hit "Passcode Lock" on the right side of the screen.
Step 4
Select the "Turn Passcode On" option at the top of the screen. You also can elect to change your password and when it is required.
Step 5
Enter in a four-digit pin that will act as your password.
Step 6
Select "Erase Data" if you would like extra security. This option will erase all data on your iPad if the incorrect password is entered 10 times in a row. You should carefully consider this option because it can be quite risky, especially if you tend to forget passwords.
1helpful
I have no pin number for my Kindle Fire. It is asking for one to use it. How do I open it without a pin. I am locked out.
Hello
Just follow these steps:
1.On the lock screen, swipe from the right side edge of the screen.
2.Enter an incorrect password or PIN (at least characters in length) five times.
3.Tap Reset to reset your device to factory defaults.
For any help or support visit us: Kindle Fire Support
1helpful
Pass word won't work
a few specifics may help you with the right answer, like which password log in for computer or account? what computer what operating system? computers are getting way too advanced to just ask a simple question without details.. thanks
AX109JC20130709
You do not say what type of password was set and if you have forgotten it or just want to reset from a known password..
If you just want to change your gmail login password
- Go to google.com/accounts on the tablet browser
- Sign in
- "Change Password"
- Go back to the Home Screen on the tablet
- Open the GMail app, clicked on Menu, then Refresh -- you will get a sync error
- Wait for a notification to re-enter your password (a triangle with an exclamation point in the tablet notificaiton bar and/or something in the gmail screen)
- Enter the new password
This simple solution sometimes works:
Turn it off.
Turn back on.
When you get the warning triangle in the notification bar, open the notification.
You will then get a login screen.
Input your new password.
Pattern Lock- Incorrectly enter pattern 5 times (4 or more points each time) . Pop up message will appear Click Next and you will be prompted for goole a/c details or security for pattern lock.
tap forgotten pattern and on next screen enter goole account details. Then next screen allows you to choose a new screen lock option.
Locked with PIN or password _Try Screenlock bypass pro from play store.
The only other solution is a hard reset which is only as a last resort. You need to access Androids Recovery mode. Check your manual. Most devices it is power off then power up holding volume + and power buttons.
Once in this mode use power down button to highlight "wipedata/factory reset option, then use power button to select it.
Vol - button to to scroll and select yes delete all user data option with power button. When device reset select option to reboot now and the device will turn on unlocked but you will have lost your personal data.
Face unlock - you were asked to provide a pattern or PIN backup when you set it. Just bypass and enter PIN or pattern.
Good Luck
I can't get into my emails
Be sure that you go into settings and see if the password is there. Usually it can grow feet and walk away and then you will be asked to enter it again. See if that helps.
Password kindle lost
You will need to do a factory reset:
  1. Enter a four digit pin at least five times. Each time you enter the wrong password, it will say, "Please try again".
  2. On the fifth incorrect attempt it will ask if you want to Reset.
  3. Select Reset and your Kindle will go through the process and you will be able to access your Kindle again.
I have a irulu tablet model AL001 my son reset the password and its asking me for my google account i put that info in and its telling me incorrect please help.....
Did your son reset the tablet password, or your google account password? if it was the google account password then if you go to the GMail website you can reset your password there. Its saying its incorrect because the information which is being entered is wrong
Still can not access my e-mail
You must enter your e-mail address and password into your service provider, I.e., Verizon, aol, Yahoo, etc., to get to the letter composition form. If the error message appears you probably entered your I'd or password incorrectly.. You may have forgotten your password. If so theSV Pro will tell you how to reset your ID or password. Good luck.
1helpful
I forgot password
If you can tell me what the Os do you use, it could be must better.
On XP you can try this:
Boot computer and press Ctrl+Alt+Delete twice when you See Windows welcome screen / login screen. It'll show classic login box. Now type "Administrator" (without quotes) in username field and leave password field blank, press Enter and you should be able to login Windows.
Now you can reset your account password from "Control Panel -> User Accounts".
On Win 7 or Vista:
Ctrl+Alt+Delete won't work, you have to use some windows password reset tool. I recommend Windows Password Reset.
Resource: http://www.windowspasswordreset.net
Heya Laptop
It sounds like you closed the lid, which put the computer into "Standby mode" (which can be seen by the flashing green lightning bolt light on the front) . Whenever you turn your computer on from standby mode, it locks the computer so that an unauthorized person can't open your computer and run your programs without permission. To log in, you can just type the password you normally type when you log in to the computer. If you don't have a password, try just hitting enter instead of typing a password. (You may need to hit Ctrl + Alt + Delete before you can enter your password, just follow the instructions on your screen)
Top Toshiba Tablets & eReaders Experts
k24674
ExpressFiX
ExpressFiX
Grand Canyon Tech
Grand Canyon Tech
Are you a Toshiba Tablet and eReader Expert? Answer questions, earn points and help others
