Check the security settings of your mail server to ensure you're not being blocked.
Here are some 'standard' settings that may work with your system.
Gmail Incoming Outgoing
Access Type Web & POP3 Web & POP3
Email Address Format
[email protected] [email protected]Account Username Format
Full email address Full email address
Server Address pop.gmail.com
Use SSL: yes Port:995 smtp.gmail.com
Use SSL: yes Port:465
Hotmail Incoming Outgoing
Server Address pop3.live.com smtp.live.com
ic24 Incoming Outgoing
Server Address mail.totalise.co.uk smtp.tiscali.co.uk
UKGateway Incoming Outgoing
Server Address pop.ukgateway.net smtp.ukgateway.net
UK Online Incoming Outgoing
[email protected] [email protected]Server Address pop3.ukonline.co.uk smtp.ukonline.co.uk
Vippowerent Incoming Outgoing
Server Address pop.vppn.com
Virgin.net Incoming Outgoing
Username Username
Server Address mail.virgin.net mail.virgin.net
Wanadoo Incoming Outgoing
Email Address Format username@ name.wanadoo.co.uk username@ name.wanadoo.co.uk
name.wanadoo.co.uk name.wanadoo.co.uk
Server Address pop.wanadoo.co.uk smtp.wanadooasdl.co.uk
World Online Incoming Outgoing
Email Address Format username@ worldonline.co.uk username@ worldonline.co.uk
Server Address pop.
tiscali.co.uk smtp.
tiscali.co.uk
Yahoo.co.uk Incoming Outgoing
Username Username
Server Address pop.mail.yahoo.co.uk smtp.mail.yahoo.co.uk
Yahoo.com Incoming Outgoing
Username Username
Server Address pop.mail.yahoo.com smtp.mail.yahoo.com
Settings - E-mail
You'll need to complete all steps for this to work. Make sure that if you have to enter O2 in the settings you use the letter O and not a zero.
The following settings are if you use O2 Email as your ISP (Internet Service Provider).
If you require different settings eg Yahoo, Gmail etc please click here
1. Tap the Application tab on the bottom of the screen
2. Tap Email
3. Tap Next on the Welcome to Email setup screen
4. Tap on the Email address text box and enter your Email address then tap Done
5. Tap on the Password text box and enter your Password for your Email account then tap Done
6. Tap Next
7. Your phone will now try and download your setting to your phone and set up your account, if this can not be done you will see the message, Setup could not finish. Unable to open connection to server. Tap Edit details to continue.
8. Tap Manual setup
9. Tap the Username text box and enter your full Email address then tap Done
10. Tap POP3 account
11. Highlight POP3 server and tap the text box and enter mail.o2.co.uk
12. Check that Port is default set at 110
13. Highlight Next and tap
14. The phone will now check your settings
15. Tap the SMTP server text box and enter smtp.o2.co.uk
16. Highlight Next and tap
17. The phone will now check your settings
18. Tap Next on the Account options screen
19. You now have the options to add a name for your new account plus add your name to outgoing messages
20. Tap Done
In Windows 7 Live Mail there is no Tools menu.
How do I get to timeout settings?
Also I am not sending large files.
It does not work with even one small photo attached.
Ordinary texted mail seems to go out OK though...
Tried that and also have the full manual which was no help.
I uninstalled Webroot Essentials and installed AVG suite.
The mail seems to go through now but there is a delay of about a minute or two,
In Live Mail I still cannot find anywhere to increase the upload time from say 60 seconds to 300 seconds,
Unless can answer that, there is no need to keep contacting me...
Thanks.
