My whirlpool washer is making a grinding noise. When I first put a load in it was fine and once it go to the rinse cycle it started grinding and now wont do nothing at all
It needs a new gearbox and clutch. It's not really the sort of job you can do yourself. The gearcase is $252, and the clutch is $51. Time for a new Whirlpool front loader. Mine is just as big and uses a tenth of the water and electricity.
Jul 27, 2015 - Agitator directional cogs aka "agitator dogs" (top load washers) ... If you hear a rubbing sound or the drum spins uneven, then the ... A washer making a loud noise during spin cycle can also be caused ... The clutch in a washing machine connects the inner wash tub to the ..... May 8, 2015; High Water Bill?
Apr 11, 2014 - Dishwasher Making Loud Grinding Noise During Wash Cycle ... GE, Whirlpool, Frigidaire, KitchenAid, Maytag, Kenmore, and LG) this is a .... Our Amana dishwasher is making a loud, high-pitched squealing noise throughout the wash ....Out Of A Washing Machine - Top Load & Front Load September 30, ...
That grinding noise your hearing is most likely the center bearing in a maytag they are usally very easy to break and mainly because when they make maytags they dont put the right type of grease on the bearing itself which causes the machines not to last the 10 years that we all think they could. This repair is honestly not worth the amount of money that it would cost to repair I've seen technicians price this job out between 450 as a low and 600 as a high and considering you can buy a brand new top loader for 2-400 it really isnt worth the effort in trying to resurect the machine. Please also note maytags are notorious for the center bearings disintergrating because of poor factory assembly. Sorry about the bad news. when looking for a new washer if your going with a top loader stick to the whirlpool there easy to fix cheap for parts and last alot longer. Please remember to rank this opinion and if i can answer any further questions please message me back. Thanks again (p.s. on whirlpool make sure if you buy a new one you ask if the drive couple has metal around the shaft dont get the plastic one they let go in two years and then techs charge 180 bucks to repair a 6 dollar part)
Sounds like you may have lost your basket drive and clutch assembly. This is a pretty involved job to replace for sure, and requires you to remove the inner basket, drop the transmission, etc. Does the unit make any wierd noises, like popping or grinding? Does it agitate ok in wash? I would bet almost for sure that its that basket drive and attached sub-pack thats went bad. If you want to try and tackle this yourself, let me know, and will get you directions to do so. Good Luck!!!!
remove the top access panel 3 screws in top rear. now look around and push on the drum from top it has suspension shocks and springs like your car they should resist any movements. look/wiggle the concrete balance blocks , no cracks or loose. inside the tub are the arm solid /not loose. run it with the top open what do you see/hear and where look under the rubber flap in front did anything get under the tub
grinding noises are never a good sign. My best guess is that the motor coupling is shot. Very inexpensive repair if you're handy. unplug and tip the machine back. locate the motor and remove the clips holding the motor/pump assembly to the transmission. carefully remove the motor and if the coupling is shot, replace. put it back together and should be good to go.
