I got a 7610 fr service when we switch on the set i display come's full white but incoming nd outgoing is going shal u tel me solution for this problem
7610 having blank display and can receive and make the calls from it so want the solution for blank display7610 having blank display and can receive and make the calls from it so want the solution for blank display
One issue you may have is outgoing mail. Some ISPs insist that all outgoing mail goes through there servers, to protect against imposed spam fines... Sometimes you have to send through another port, gmail does that....Then ISPs usually let that go...Much better setting for mobile user...
Go to Tools and Account Settings - below the E-mail tab click New
Choose E-mail Service. Click on the Microsoft Exchange, POP3, IMAP, or HTTP radio button
Click the manually configure server settings or additional server types check box. This will automatically enter in all of the required fields
Click next
Click on the Internet E-mail bubble. Click next
Enter the following information:
Your Name: Display Name you want to use, for example, Jo Bloggs Email address: Full email address, for example, [email protected] Incoming Server: Contact your ISP or Hosting Company for this setting. (See note below if your mail provider is Yahoo!) Outgoing Mail server: Contact your ISP or Hosting Company for this setting. (See note below if your mail provider is Yahoo!) User name: The first portion of your email address, for example, jo.bloggs@domain.com Password: Your email account password
Note: If your mail provider is either yahoo.com, rocketmail.com, or ymail.com then the incoming and outgoing settings are as follows:
Incoming Mail Server pop.mail.yahoo.com
Outgoing Mail Server smtp.mail.yahoo.com
If your mail server requires SMTP Authentication, follow these steps. If you are not sure if your mail server requires SMTP Authentication, please contact your hosting company or ISP:
Click on More Settings
Navigate to the Outgoing Server tab
Check My Outgoing Server requires SMTP Authentication
Incoming white - outgoing white
This is the neutral, which just passes through without connecting to the switch
incoming black - switch black
the hot wire provides power to the switch
switch red - outgoing red
a traveler, will have power when toggle is one position
switch yellow - outgoing black the other traveler, will have power when toggle is in the other position
incoming bare - switch green - outgoing bare
the switch is grounded and it passes through
Can you tell me where the outgoing wires are going to. Bare wire is ground goes in green color screw, white wire is neutral and goes in silver color screw, black wire is hot or live and goes in gold color screw. It is difficult to help you with little information. how do you know what is incoming and outgoing.
Friend, it is very simple the LCD is disconnected you need to press it firmly enough to get the proper connection. it is in the flex interface connector.
ganun din
kaso pinalitan n ung akin pero ganun pa rin
after two days simula nung pinalitan
nag blank ulit sya
