Cozy (W352E) Heater Logo
Posted on Dec 27, 2009
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
I replaced the thermostat because it wouldn't turn on, it still doesn't turn on. What else can I check?
Anonymous
Level 3:
  • Master 1,420 Answers
  • Posted on Dec 27, 2009
Anonymous
Master
Level 3:
Answers
1420
Questions
Helped
849200
Points
3861
Jump the two thermostat wires together at the thermostat, if it fires up; it is a bad thermostat. Jump the terminals where the thermostat connects to at the gas valve, if the unit fires it is a bad thermostat wire or connection. If the unit does not fire, check for 24 volts AC out of the transformer. If yes, bad gas valve, if no bad transformer or no power to transformer.
Anonymous
Level 1:
New Friend:
  • Contributor 1 Answer
  • Posted on Jan 02, 2010
Anonymous
Contributor
Level 1:
New Friend:
Answers
Questions
0
Helped
368
Points
I'm having the same problem and heater is only a yr old I am a disabled vet and on a fixed income so i can't call a repair man If any 1 has a solution please help
I have an older rear engine snapper riding mower. My son hit a soft ball and it turned off and wouldn’t restart. I replaced the flywheel key that was sheared but still won’t start. It has a spark but...
Timing of the magneto to the coil is critical. so is the gap between the magnet and the coil. Double check both, the gap can be set to .01 to .019 depending on the make and model of the motor and you did not post that.
1helpful
My whirlpool dryer comes on and runs good but it wont get hot can you tell me whats the problem
Hello there and welcome to fixya there are several things that could make this dryer not heat up
Here are the most common things
Thermal Fuse
If the dryer doesn\'t heat, but the drum
turns, check the thermal fuse(s). The thermal fuse protects the dryer
from overheating and helps to prevent fires. If the thermal fuse is
blown, it will have to be replaced.
Enter your model number to see parts for your dryer.
Help me find my model number
Gas Valve Solenoid
The gas valve has two or more electric
solenoids which open the valve to let the gas flow into the burner
assembly. If the dryer doesn\'t heat one or more of the solenoids may be
defective. If the igniter glows for 90 seconds but the burner flame
doesn\'t light, replace these coils as a set.
Dryer Igniter
If the dryer doesn\'t heat, the igniter might
be burned out. Check the igniter for continuity with an ohm meter. Dryer
igniters burn out over time, similar to a light bulb.
Heating Element
The heating element on an electric dryer can
burn out over time. If the dryer doesn\'t heat, the element should be
checked for continuity. The heating element cannot be repaired and must
be replaced if defective.
Heating Element Assembly
the heating element assembly on an electric
dryer can burn out over time. If the dryer doesn\'t heat, the element
assembly should be checked for continuity. The heating element assembly
cannot be repaired and must be replaced if defective.
Flame Sensor
Gas dryers have a flame sensor to detect the
heat given off by the flame. If the dryer doesn\'t heat, the flame sensor
might be defective. Check the flame sensor for continuity. This is not
as common as a burned out igniter or thermal fuse.
High Limit Thermostat
Although not common, if the dryer doesn\'t
heat the high limit thermostat can be defective. It can be checked for
continuity. If the thermostat is "open" the dryer doesn\'t heat.
Cycling Thermostat
The cycling thermostat regulates the
temperature of the air in the dryer. If the dryer doesn\'t heat it may be
caused by a defective cycling thermostat. This is not common.
Main Control Board
The main control board is normally not at
fault when the dryer doesn\'t heat. Check all of the other components in
this troubleshooting guide before replacing the main control board. The
main control board cannot be tested easily and must be replaced if it is
defective.
Timer
The timer is normally not at fault if the
dryer doesn\'t heat. In many situations where timers are replaced they
end up being returned. Check all of the more common components in this
troubleshooting guide before replacing the timer
Oct 14, 2013 • Dryers
96 Firebird, Replaced water pump, fuel pump - Now blows head gasket.
Get yourself another mechanic. This guy is not doing his job. It shouldn't cost $1600 to change a water pump and fuel pump. No proper mechanic would remove a thermostat to replace the O-ring and put the old thermstat back in. It wouldn't be uncommon for the coolant level to drop after changing the thermostat. It probably only needs to be topped up. No, the motor doesn't have to come out to replace the head gasket and I don't see it costing $2500. Before you spend any more money there, take the car somewhere else and get another opinion. I bet that if you fill up the coolant bottle for 2 0r 3 days it will stop losing coolant. Hope this helps.
I have a 1996 Chevy Blazer 6 cylinder 4.3 Vortex engine. The check engine light has been on for a few weeks but it was running just fine. Until all of a sudden it wouldn't start last night. I had...
My first thought would be: If you repaired an emissions hose, take the car back to Auto Zone (or another parts supplier) and let them tell you what code comes up now. You eliminated one problem, now you have to find another.
I wouldn't do a fuel pump without more information.
Gary
Car heat rises right to the red then if you turn on the heater it fall to half way mark. if i remove the thermostat will it fix enough to sell it. and is it in upper hose or lower?
Doesn't sound like a thermostat problem. I would look at the radiator grill and make sure it isn't clogged and check the water pump to make sure it is working and check the cooling fan for the radiator. The heater in the car has lines connected to the motor and when that is opened and the water is allowed to flow through you have essentially a mini radiator working. The thermostat may in fact be sticking but I would look at other areas for the main problem. If you have been running straight water and not a mix with antifreeze the radiator core may be clogged from build up. Finally, make sure your overflow jug is properly filled and the radiator is topped off. As far as selling the vehicle without a thermostat, to overcome the proper so you can unload it. I wouldn't, they have made significant changes to the laws regarding this tactic and it can come back to haunt you, additionally if you take it to a dealer they are going to check for that trick the same way they check for Sawdust in the transmission and metal in the engine oil before they offer to buy it or take it in trade because they can lose their license if they get caught selling a vehicle that way.
Two winters ago i had to change out my thermostat. Then last summer my AC wouldn't turn on. So i thought it was the thermostat i had so i just went and bought a better one. but still the Fan on the AC...
If the compressors running and the fan is not you should check the fan motor capacitor and check for power at fan motor if power is there you have bad fan motor
Lately when I drive my 1996 Volvo 850 in the summer it doesn't want to start if the outside temperature climbs to over 26 degrees celcius. I drive somewhere no problem and turn off engine. Go into a...
For bdjenn, I have a 94 850 non turbo with similar problem. You might need to replace the fuel pump relay. Part costs about $50, is located next to fuse box. Also, check the thermostat in the air box under the air filter. The thermostat costs about $20 and often goes bad. When not working, it fails to shut off the hot air and doesn't let cooler, outside air in. Many people just remove the thermostat and fix the cool air intake to stay in the open position. This could be a problem in the winter if you live in a cold climate.
Top Cozy Heating & Cooling Experts
Paul Carew
Ronny Bennett Sr.
Ronny Bennett Sr.
Mike Cairns
Mike Cairns
Are you a Cozy Heating and Cooling Expert? Answer questions, earn points and help others
