When a tape won't eject, the problem can be caused by several things. The most common problem is that the belt that operates the eject mechanism is slipping and not allowing it to eject the tape. This can be fixed by either using a re-grip solution on the belt or having the belt replaced. With the cover off (be careful not to touch anything live with power) and try loading and unloading a tape. Try to find the motor and belt which operates the loading mechanism. When it "catches" as you say, try moving the belt pulley with your finger to give it a little help and see if it continues on with the operation. If it does, the belt is probably slipping. It takes more effort on the belt & pulley during an eject sequence rather than the a load sequence, so it may load fine but have trouble ejecting. Gravity and the weight of the tape is why you may not have this problem during the load sequence.
You will need to take the cover off. Try to find the motor and belt which operates the loading mechanism. Try moving the belt pulley with your finger to give it a little help and see if it continues on with the operation. If it does, the belt is probably slipping.
Hopefully, you won't find any spilled tape in the unit.
Let me know what you find out and we'll go from there.
Good Luck, JimYou will need to take the cover off. Try to find the motor and belt which operates the loading mechanism. Try moving the belt pulley with your finger to give it a little help and see if it continues on with the operation. If it does, the belt is probably slipping.
Good Luck, Jim
You can't post conmments that contain an email address.
There seems to be some damage to the cassette holder. It could also be something connected to the mode switch, being faulty or in the wrong position. Pressing down on the tape would not have helped it either!
Now-a-days most of the gears are made out of plastic(HDPE, if I remember correctly), when the rewinding command is given even if one gear tooth is worn/broken it will throw the entire timing out of 'gear'. Since the problem has already occurred, and, this is the only function that has malfunctioned my advice would be to leave it as it is! ('cos repairing/replacing it is manual & therefore a costly affair plus there is no guarantee that the replacedment will function properly)....sodeep
It sounds like the vcr is not completely loading the tape, and is overloading or getting confused. If you feel up to it, you can take the cover off the tv, find the tape loading mechanism, and 'help' the loading rollers along yourself... once the tape loads, eject it immediately, and you should be off and running again. Just be careful not to touch any electrical connections. If you're not comfortable with that, you're right, it's probably cheaper to get a newer tv - check with a local independent shop first, though, it should be a really quick fix.
The tape mechanism is not loading and/or driving the VCR tape properly. Most people don't realize that the tape is physically pulled out of the VCR cassette and wrapped around the video heads in a semi-circle configuration. Your VCR guides are pulling the tape out but not retracting it into the cassette shell when you press eject. Causes: mode switch, mechanical failure, video head speed/drive problems. All these problems are somewhat complex for a novice repair person and don't forget that new VCR's are selling for $30 at the big box stores....Glen.
Most VCR's will auto-rewind the tape when it gets to the end of a tape. Most will leave the tape in the unit assuming you may wish to view it again once rewound. Does the tape eject properly when you press the eject button? What does the manula say about the eject function?
Typical belt drive failure. Take the cover off and turn the
loading motor shaft with your fingers until the tape is ejected.
Get a belt kit for this model and replace all the rubber parts in
your VCR. Mitsubishi's are nice units and worth fixing.
Check the little pulley under the capstan motor for cracks or worse.
the end-of-tape optical sensor is at fault. either it is very dirty, has failed or something else is detecting end of tape. many VCR's now will auto-eject the tape upon end of tape detect
