Frigidaire ATF6000ES Front Load Washer Logo
Posted on Jan 27, 2008
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Frigidaire washer model #fwt425rhso
Washer goes though wash cycle fine , but when high speed spin cycle starts loud banging starts sounds like it is coming from the back
  • 6 more comments
  • cheese242 Jan 27, 2008
    the nut at the back is tight, i lift the drum from the inside and it moves about 1/4 to 1/8 of an inch the noise sounds like marbles banging around
  • cheese242 Jan 28, 2008
    what does the drain pump have to do with my problem?? the noise almost sounds like the drum itself and the flywheel are banging together at the high speed rinse. I have occainally had some grease on some clothing bearing maybe??
  • trini1 Feb 03, 2008
    I have the same problem with my Frigidaire washer and when I opened it up the housing that holds the shaft for the inner wash basket was broken. This seems to be a common problem with these front loading washers. I checked my warranty and there is a 25 year warranty on for a replacement part for the inner wash basket. DO NOT use the washer because the vibration and noise could detach the front rubber boot from the inner basket making this a more expensive than it already is.
       Call Frigidaire and see if this is the part that is covered under the warranty because I am calling them tommorrow.
  • Honeymooner Feb 21, 2008
    During the final spin cycle our machine sounds like boulders are banging around in the machine. We have taken apart the outer panel and nothing is broken, have not opened the housing to the basket though. This sound is not during the spining of the normal part of the cycle only during the last final spin. Help!
  • pinkpryncess Apr 13, 2008
    I am having the same problem but i also am having an additional problem. I absolutly hate this washer and dryer if I could have my old ones back I would!!!
  • Anonymous Apr 15, 2008
    VIBRATES BADLY IN MEDIUM SPIN CYCLE. TWO TECHS LOOKED AT IT AND SAID THATS HOW THEY ALL ARE. WISH I HAD MY OLD MACHINES INSTEAD OF THESE
  • Anonymous Jan 08, 2009
    Frigidare 9 cycle 2 speed washer . won't drain out water during rinse nor at the end of the wash cycle?
  • Anonymous May 11, 2010
    open the top and check to see if the nut is tight on the top belt pully on the drum
A
Anonymous
I had the same problem with noisy spins - rear basket support was cracked in 9 places.
Anonymous
Level 3:
President:
  • Master 1,314 Answers
  • Posted on Jan 27, 2008
Anonymous
Master
Level 3:
President:
Answers
1314
Questions
6
Helped
897527
Points
3823
The tub is mounted on shocks if you look in side the tub near where the tub seem is take the screws out of the vane and slide it foward and take it out look in the hole for foreign objects in between the inner and outer tub then follow this procedure to check the drain pump if you have a shop vac this is time to vacuum the water of the tub and all the way down the drain hole for the next stage usally i tell customers to remove the drain hose from the stand pipe and vacuum the water out of the washer from the drain hose but because of the pillow this might not work in your case. Now remove the two screws on the front lower panel and pull the panel
in side you will see the drain pump if you did not have a shop vac go to the auto parts store and buy a pair of radiator hose clamps and clamp the hose line as close to the washer as possible.(but put down some towels as water always stays there) then pull the tub to pump hose by depressing the squeeze clamp(now while your at the auto parts id get a screw clamp to replace the spring clamp it makes putting the hose back on a lot easier)pull the hose off.Then pull the pump to drain hose off .Remove the two 5/16 in screws securing the pump to the washer base.Unplug the connector and remove the pump inspect the pump for foreign objects,broken or stripped impeller blades . if the impeller are stripped you will have to replace the pump then form the front of the washer take a piece of water hose with one end cut off and run it down the pump to drain end of the drain and reassemble the unit
  • Anonymous Jan 28, 2008
    its possible its a rear bearing how old is it and the drain pump runs the whole time during the spin cycle so if a foreign object is in it can make a rattling sound its just a possibility grab the rear flywheels and see if it has side to side play
Anonymous
Level 1:
  • Contributor 1 Answer
  • Posted on Oct 20, 2009
Anonymous
Contributor
Level 1:
Answers
Questions
0
Helped
1297
Points
This is the second time I have had to replace the drum/support shaft on this washer. Not only is it expensive, but very difficult to replace. Probably the very worst washer on the market for this reason. And I only do 3-4 light loads of laundry per week. A definate design flaw on the part of the manufacturer.
I have a top load fridgidaire washer model fwsc445rfs0. During the wash cycle it makes a high pitched scraping noise.... Struggles also while it winds down before rinse. Bearing maybe?
How To Fix A Washing Machine Making Noise During The ...
removeandreplace.com/.../washing-machine-making-noise-during-the-sp...
Jul 27, 2015 - Agitator directional cogs aka "agitator dogs" (top load washers) ... If you hear a rubbing sound or the drum spins uneven, then the ... A washer making a loud noise during spin cycle can also be caused ... The clutch in a washing machine connects the inner wash tub to the ..... May 8, 2015; High Water Bill?
Dishwasher Making Loud Grinding Noise During Wash Cycle
removeandreplace.com/.../dishwasher-making-loud-grinding-noise-durin...
Apr 11, 2014 - Dishwasher Making Loud Grinding Noise During Wash Cycle ... GE, Whirlpool, Frigidaire, KitchenAid, Maytag, Kenmore, and LG) this is a .... Our Amana dishwasher is making a loud, high-pitched squealing noise throughout the wash ....Out Of A Washing Machine - Top Load & Front Load September 30, ...
All comments on Loud dishwasher Frigidaire Gallery mode ...
https://www.youtube.com/all_comments?v=v-arYb20kOk
2helpful
The drum is making a loud banging sound. Help!
if it's banging loudly in the spin cycle most likely the spider gear broke,usually from using to much detergent and overloading the washer,for it would cost to repair it you'd be better off repalcing the washer,you
Loud banging noise during final high speed spin
I have the HE3T which is 6 yo. Last week it started making a loud banging noise in the spin cycle. I had a repairman come out. He said it is the drum bearings. He said that it is a problem with these machines and to call Sears. He said that the drum and bearing is one assembly and that Sears should cover it.
I called today and Sears todl me that I have to pay for a Sears technician to come out a determine if it is indeed the problem. If so, it will be covered under the lifetime warranty on the drum. I have to pay for the service call $75.00 and if it is the problem, I will be reimbursed. Cross my fingers!
Washer will not go into fast spin cycle
SOUNDS LIKE YOU MAY HAVE TTO REPLACE YOUR BELT ON YOUR WASHER. I AM NOT A MECHANIC, BUT I THINK THIS WILL HELP.
Kenmore washer loud bang in spin
Great!! Thanks for the followup -- I mean really, thanks!!
Loud noise
it sounds like you have something stuck under the agitator thats causing a rubbing noise when it goes to spin or agitate.maybe a penny or something like that
Drum Speed - Unstable
The spin bearing or basket drive may be worn. When these components are worn-they prevent the drum from spinning freely, and usually you hear a loud sound during the spin mode.
Vibrition at high speed
investigated further by myself couldnt wait
Top Frigidaire Washing Machines Experts
ZJ Limited
ZJ Limited
Mike Cairns
Mike Cairns
Are you a Frigidaire Washing Machine Expert? Answer questions, earn points and help others
