Meade ETX-70ATE Telescope Logo
Posted on Dec 27, 2009
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Meade etx70at telescope drive works in up/down but in left/right, motor runs but telescope does not turn regardless of friction position. can it be lo battery voltage?
Joe Lalumia aka TelescopeMan
Level 3:
  • Master 3,186 Answers
  • Posted on Dec 28, 2009
Master
Level 3:
Answers
3186
Questions
Helped
951829
Points
7111
You did tighten the azimuth lock on the base of the telescope under the tube?
1helpful
Meade LX90 GPS - When the telescope slews to a new location (tour or manual slew), the telescope then slews up a few degrees. I have to manually slew the scope down several degrees and hope I've...
Calibrate motors and then TRAIN the drives-- this sets the gear backlash.
You should Calibrate motors every time you take it outside and Train drives at least once every year. The symptom you describe is called "rubberbanding".
Train the drives.
I have a Meade DSX Telescope. I haven't used in years. The motor operates and moves the telescope up and down, but not horizontally anymore. I can here the motor working but it's not turning? Perhaps dust...
I dont think is the dust problem ..but if you are handy enough open it and take a look ..probably ..if it the same motor for both actions ..it has a drive belt or a gear to operate that it is not OK ...and it will be visible ...If it is a 2 motors operable ..one of them is defective ..and need to be changed..
Meade DS-2114S, can not get the vertical, up/down movement to work when using the autostar mode, can hear the motor drive working but no movement, the left / right moves fine, and the up / down moves fine...
The knob on the fork arm is tightened? Correct. You can slew manually, but cannot do a two star alignment?
Is all of this correct? Post a reply with additional information.
You have trained the drives -- correct?
On autostar I can move the telescope up and down with the remote and not right and left. Motor gives the sound that if it is trying to move right and left but nothing happens till I do manually and then...
The Azimuth clutch is slipping-- have you tightened the knob in the center of the base-- push the handle to the left. There is a tiny set screw on the side of the knob -- you can loosen it and remove the knob and position it further to the RIGHT on the bolt.
Meade/auto star problem
You never said what model. The CD ROM only contains free planetarium software which you can also down load on Meade's web site here:
www.meade.com look under the Customer Service link.
Motor Faults are usually caused by low power and or a broken part.
If you have CALIBRATE MOTORS feature in the hand controller do this first. If it still does not work, RESET the hand controller, reenter date, time, and SITE, and calibrate motors again.
If this does not work something is broken inside the scope.
1helpful
ETX 60 altitude doesn´t work, but motor works
You need to tighten the friction lock - it acts as a slip clutch.
1helpful
Meade autostar computer wont go up or down only
Could be just a bad cable. Contact Meade customer service.
http://www.meade.com/support/index.html
Top Meade Optics Experts
ADMIN Eric
ADMIN Eric
Tony Parsons
Tony Parsons
Are you a Meade Optic Expert? Answer questions, earn points and help others
