Hitachi 50UX57B 50" Rear Projection Television Logo
Posted on Jan 27, 2008
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Blurry on left side of the screen. Shadowing in different colors.
The picture is blurry on the left side of the screen only. Green, Red and Blue shadows on subjects and text.
Anonymous
Level 2:
Scholar:
  • Expert 128 Answers
  • Posted on Jan 28, 2008
Anonymous
Expert
Level 2:
Scholar:
Answers
128
Questions
Helped
147938
Points
259
Try this website. It is the Hitachi support website. http://www.hitachi.com/GlobalSupport/ContactUs?form_type=global_support Hope this helps :)
Sony KDL-52WL130 Dark and blurry on left side of screen . Also vertical lines on left side of screen
The TV requires thorough servicing and this might require attention by a qualified service technician.
LEFT SIDE OF PICTURE IS BLURRY AND COLORS DISTORTED
Does that set have whats called a color wheel, if so that maybe you problem, and replacement is how you fix it.
The left side of screen is blurry.
These sets need to have all three colors - RED - BLUE - GREEN - lined up correctly on the screen in order for the picture to look normal. This is called convergence.
When its out of alignment the video will look 3-D, wavy, distorted, etc. Most of the time you just need to adjust your convergence in the menu. If you cannot adjust it in the menu - then your convergence is broken and needs to be repaired.
Convergence problems are very common on all Projection TV sets including Sony2_bing.gif,Samsung, JVC, Philip Magnavox, Panasonic, Akai, Pioneer2_bing.gif, Hitachi, Zenith, and others. You can get a convergenece repair kit wiith instructions from the links below.
Here are some of the most common problems with these sets...
Problem #1) Convergence
Yours may have one or more of the following symptoms
  • Screen Looks 3-D
  • Colors wont align
  • Screen may look distorted or warped
  • No Audio/Video - makes a chirping sound.
Problem #2
Another common problem is dull or washed out video.
Your set may have one or more of the following symptoms....
  • Dull looking picture
  • White looking picture
  • Halos around objects
  • Red/Orange looking picture
You can see some more examples and find a fix here
bb0cf99.pnghttp://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
1helpful
I have a rear projection Hitachi Utlravision HDTV. Today, it started showing pink and green shadowing on the left and center area of the monitor, which makes words and shapes look pretty blurry. Everything...
It sounds like a Convergence problem--go into the customer menu with the Hitachi remote and select convergence---look to see if one of the colors will not move---you can only move red or blue-----if something will not move you have a convergence problem.
Let me know here what you find and I can tell you what is involved if it is a convergence problem.
REGARDS, SD TECH
1helpful
I left my tv on when I went to bed and the picture was fine. Then I woke up and turned it off. When I came home and turned it back on, the picture was blurry all around the tv except in the middle of the...
is the blurry all around the picture have different color like a smear of red, blue or yellow?
if it is i think the posistor of your tv is not working. it is the one who activate the degaussing coil around the picture tube the prevent color miss-landing upon opening your tv set.
Shadowing and blurriness
needs a convergence board repair, not too hard to fix if you are handy with a soldering iron.
get the 2 convergence chips for this model @ partsstore.com
Blurry screen KP61hs10
Yes, Convergence settings should be tried first before any color adjustment or any fluid changes are done. Remember that there are 3 colors to notice. Red, Green, Blue. The Green is the only one that you can not move with an adjustment The Red and Blue is ligned up on green. Some cases it does matter how linear the Green color is across the board, just how close you get the blue and red on top of green is what matters.
2answers
Blurry on one side of screen. Green and purple shadows
Convergence IC's should be replaced before any alignment is
attempted ....part # STK392-560....You need two......mount
to large heatsink...............T.
Rca d61w20 dominate red & blue screen also very blurry picture
Red and blue present, but no green = bad green CRT is
best guess.Remove lower front panel = adjust screen and focus
controls for best pix..................T.
KP-53s65 multipule problems, hoping for single solution?
sounds like 2 different problems here. first problem sounds tuner related. second sounds convergence related. third issue (cost effective to repair ?) at this point i would replace the set. i hope this helps
Top Hitachi Televison & Video Experts
Grand Canyon Tech
Grand Canyon Tech
matt martin
matt martin
Are you a Hitachi Televison and Video Expert? Answer questions, earn points and help others
