Question about Voyetra Turtle Beach Ear Force X1 Headset
My turtle beach headset is buzzing on the left side
I need some help its buzzing big time and its starting to make me mad i dont kno what to do can someone help me
    Scholar:
  • 63 Answers
If you plug the X1 USB plug into a USB port on a laptop instead of the USB port on your Xbox, does the buzzing go away? If yes, then an AC-to-USB power adapter should fix the problem for you.
Posted on Feb 24, 2010
6ya staff
SOURCE:
95 Taurus 3.8 SHO wont start replaced everything fuel pump to big relay is buzzing even new one im lost need help
Run tests. Fuel pressure correct? Spark at plugs when cranking? Fuel injector pulse working? Compression test?
Apr 06, 2015 | Cars & Trucks
Quinny buzz, awful knocking noise from wheels, driving me mad. How do i fix this please? Someone mentioned it could be wheel bearings but i can't seem to be able to buy just wheel bearings Can anyone...
Hi Sophie
Wheel bearings themselves are not available as spare part items. It would be a case of replacing the complete wheels. Spare parts can be ordered via your local retailer or direct with the customer care team - full info including spare parts RRP can be found on our Note Quinny Buzz Quinny Buzz Xtra Spare Parts
May 11, 2014 | Baby Gear
Wont start.buzzes.unplug to turn off
Possible unbalanced load in the washer. I have found this to be the case in other types of top load washers. Just redistribute the load the try again. If this works, washer is doing what it needs to do to keep from spinning madly out of control and extending its life!
Feb 25, 2014 | Whirlpool Cabrio WTW6600SBT Top Load...
Help car wont start 1997ford tauru I start engine rotates but wont start
have someone turn the ingnition on ( without starting the car ) while you listen by the gas tank. if you dont hear a buzzing sound coming from the tank then the fuel pump needs to be replaced. if you do hear a buzzing then your problem is most likely spark issue. pull a spark plug out of the motor plug it back into its wire and have someone turn the car over and check to see if it sparks. is the check engine light on?
Nov 07, 2011 | 1997 Ford Taurus
I went threw a big puddle with my saturn and it quit and now it won't start and won't even turn over need some help
you have a firing issue .. replace complete spark system plugs wires distributor cap rotor button and coil what happened is you got it wet and coil broke down water got inside distributor cap and messed it up .. you might even have to go as far as to replace the entire distributor
Sep 18, 2010 | 1999 Saturn SL
Any one kno anything about these kicker zx 2500.1
yea u should as long everything is hooked up correctly ur sound will be great u dont need all that. all of those is because his pushing alot of power and a giant amp its most for that big amp.
so yea hook it up and it should sound good
Jun 27, 2009 | Car Audio & Video
Blurred Taking Pictures, But not all the time???
lens misallignment due to worn out gears on focus adjustment (zoom in/out), needs repair but could be expensive and not reliable enough.
May 20, 2009 | Casio Exilim EXZ75 Digital Camera
Rear speaker buzz!!!!!!!!!!!!!!!
i had the exact same problem which eventually spread to all speakers i took it to local repair guy, he was able to resolder the power board seem to fix all didn't really cost me much cheaper thean shipping back to spherex or whoever
Sep 30, 2007 | Spherex Xbox 5.1 Surround Sound System...
High pitched buzzing driving me mad!
Coils and trasformers create this noises,a qualified tech will have no problem find it,You should not do it if you dont know how and where to look.
Sep 12, 2006 | Bush WS6671 28" TV
Voyetra Turtle Beach Ear Force  X1 Headset Logo
239 people viewed this question
Top Voyetra Turtle Beach Radio Communications Experts
Ekse
Michial Gueffroy
Greg Ulan
Are you a Voyetra Turtle Beach Radio Communication Expert? Answer questions, earn points and help others
