Wireless CSR4.0 Portable Bluetooth Receiver Wireless Hands Free Calling for Home 3.5mm Audio Out Music Streaming Sound System Amazon com Charm sonic Wireless CSR4 0 Portable Bluetooth Receiver...
My tv is wall mount,i have hdmi from receiver to tv , im trying to hook up wii, can i tie it into receiver and how do i do it
Your post indicates the use of a receiver. If you are in fact using a receiver, make sure you have a "video out" connection from the receiver to your television. Then make sure you have the correct input selection on the receiver, and on the TV.
First, you must figure out If your TV has component video inputs. This is a set of five cables (red, blue and green for video and red and white for audio) and will give you the best picture on an hdtv
Then, If your TV does not have the component video cables, you will be using the red white and yellow composite yellows the system came with. A very simple connection.
Last, If your TV does have the component video inputs, you will need to buy a set of the Nintendo Wii Component Video cables from Walmart, Target or any other gaming store. These will enable widescreen view and the best picture quality.
To connect your DVD player, you need to located the composite video inputs and s-video. Composite video is a yellow, female RCA jack, normally found next to two audio jacks, one red, the other white. The three jacks together provide an interface for audiovisual connections. The red RCA jack connects the right channel of a stereo system, while the white RCA jack connects the left. The yellow composite video jack rounds out the set.
When playing the Wii, you will need to be on the correct video input "Component"
When playing the DVD, you will be on "Composite/Svideo."
