Question about Ricoh Aficio 2027 All-In-One Laser Printer
Ricoh AP610N error message SC-545
Help Please! Printer won't work because of this error - can anyone shed some light on how to fix it. THis is quite an urgent issue. Thanks to anyone who can shed some light.
  • Anonymous Apr 17, 2009
    this work for me twice
    Hi, i recently got this error on Ricoh Aficio AP 610N
    and This was the Fix..
    0.- Hold on your breathe...
    1.- Turn Off the printer.
    2.- Press "ONLINE and SCAPE" buttons..
    3.- without stopping pressing them (ONLINE and SCAPE) TURN ON THE PRINTER.. and wait about 10-15 seconds and Service menu show up.. after this.. release the buttons...
    4.- Go to.. Engine Maintenance... Enter..
    5.- Search for SP5810 (Fusing err clr) and Enter.
    6.- Accept the change and enter...
    7.- Turn off the printer...
    8.- Finally turn on the printer and try to print something :)
    9.- if the printer works.. you can breathe again :)
    Thanks to everybody..
  • Anonymous May 11, 2010
    Solution number 2 worked for my 10 month old Aficio SP C410DN. The menu was different but it worked.
    THANKS VERY MUCH - Saved me a service call.
Posted on May 21, 2008
  • Carrie Wrich
    Carrie Wrich Oct 31, 2014
    It worked! and I didn't even hold my breath! :-) Thank you!
  • muhammadassu
    muhammadassu Feb 19, 2016
    great....I breathed again
  • 417 Answers
HI there the following is taken from the service manual best to install new fuser unit.
545 A Fusing lamp stays on
The fusing lamp stays on more than 12
seconds after the main motor has been
turned off.
• Fusing thermistor defective
• Power supply board defective
• Defective connection of the
fusing unit
The most common thing is that the fuser thermistor is dirty and stays on trying to obtain the correct temp.
Thanks J
Posted on Jan 28, 2008
Infiernet's solution worked like a charm! thanks so much!
Posted on Sep 07, 2009
The solution from infiernet fix my problem.
Posted on Nov 19, 2008
  • abdelrazekaz Nov 14, 2010
    New Friend:
Thanks.. I installed a NEW fuser main kit and still had the sc542 error.. and I rested this value and it is working again..
Posted on Nov 19, 2012
    New Friend:
A melhor coisa, é deixa pra lá, não esquenta a cabeça, deixa a fritura pro fusor ... liga pro técnico de deixa esta impressora de lado ...
concorda ?
Posted on May 14, 2011
6ya staff
SOURCE:
How to resolve err sc 326 aficio ap610n
go to the following sites and post the statement like this:
ricoh ad 610 error message sc 326 aficio ap610n
at the following sites.:
www.ask.com
www.about.com
www.info.com
www.wiki.org
thank you rod
PS you may want to go to the manufactures web site and ask the same question as stated above.
Mar 04, 2015 | Ricoh Ad 610 - Duplexer - For Aficio...
The Ricoh Mp 2000 copier displays "Error occured Sc:545 Functional problem"
It's a fuser overheat error enter service mode to clear, if it comes back service call ( push in sequence clear modes(yellow) 1 0 7 hold down stop for 5 or so seconds, screen will change, power down, red switch. -Carl
Jan 30, 2014 | Ricoh Aficio MP 2000 Black and White...
My printer ricoh aficio SP 3400SF is showing service call error code SC542. kindly help to come out of this error. \r\nvr babu
FOR RICOH AFICIO SP 3400SF follow below steps.
1. To access Service Mode, On Control Panel press following buttons one
by one immediately.
Cancel Button (Red) ---> 1 (Numeric One) ---> 0 (Numeric zero) ---> 7
(Numeric Seven) ---> Copy Button (Green)
2. In Service Menu you will find Engine reset Menu. In that you can reset
SC 545 in Fuser Reset Menu. And you can also reset SC 542.
Jun 23, 2011 | Ricoh Aficio AP3800C Laser Printer
My Ricoh AP610N is flashing error code SC 998 power on off. How do I fix this problem asap?
sc998 is either a problem with an application, or the firmware that controls that application. If you have a service technician come out and update your firmware, it will most likely fix the problem.
Jan 18, 2011 | Ricoh Aficio AP610N Laser Printer
Ricoh Aficio MP1600 Le
Is your Windows 7 a 32 or 64 bit? Which driver are you downloading? Recommend PCL5c...
Feb 10, 2010 | Ricoh Aficio 1515MF All-In-One Laser...
Ricoh Aficio AP400N Laser Printer Sc 545 off on error
SC 545
12 seconds after the main motor has
been turned off.
• Defective connection of the fusing
This will not reset by turning of/on must enter sp modes to clear this error.
Due to possibility of fire hazard would be best to have tech look at it
Oct 09, 2009 | Ricoh Aficio AP400N Laser Printer
Error Box on Scree with Error SC-545
Hello sir; According your message, I guess your copier should be Ricoh, any way need to reset your machine, just follow following steps;
1, press "clear mode", "107", and hold down "clear/stop" key until screen change message.
2, turn power off and back on,machine should be in working now.
May 29, 2009 | Ricoh Office Equipment & Supplies
Ricoh Aficio 2027 All-In-One Laser Printer Logo
13,962 people viewed this question
Top Ricoh Office Equipment & Supplies Experts
gggg
Adorjani Laszlo
quennie732
Are you a Ricoh Office Equipment and Supply Expert? Answer questions, earn points and help others
