Safety key is inserted but still same msge.
SOURCE: Treadmill LED Track does not go to start with key inserted
I pulled the safety switch out, and the elevation is stuck on 10 degrees
SOURCE: My Freespirit treadmill is asking me to put on the safety key i
Sounds like the internal switch has ether move position or has become defective. You Will have to remove the upper console and locate the switch either on upper electronics or the console assembly have a ohm available when using the key to engage the switch you'll see if its working properly
SOURCE: my freespirit treadmill showsL5 on nthe display then quits
If calibration doesn't work replace controller.
SOURCE: 9500HR Next Generation Remanufactured Treadmill: hi i am looking for buy a safety key for my fr...
You can possibly try this site http://www.treadmilldoctor.com/Safety-Keys_18
SOURCE: i borrowed evo treadmill 500i,
Maybe it uses a magnet, like mine does. Are there any conspicuous places on the front that you might think a magnet may be placed? Mine is on the lower front left side and has a square, pushed in molding in the plastic where the magnet sits.
