I am getting a "mode is unsupported" message on my Samsung DLP HLR-4677 when we play any PS3 game other than the Simpsons. WHy is that?
Newer games such as Harry Potter and Assasins Creed give us the unsupported message. I have tried HDMI and component cables and still get this message. Ideas?
SOURCE: Samsung HLP5063W-Picture Dropping Out Using HDMI
is the eprom settings set correctly for the input beeing used,you must enter the service mode to inspect and adjust the settings,call your local dealer for assistance.
SOURCE: hi definition picture via dvi now component 1 'not supported'
you probably need to go into the menu and change the settings back to non hdmi try this first then let me know if you need further assistance
SOURCE: connection error from ps3 to tv.
When you hit the power button from the console, hod it until it beeps at you twice and it will reset the video settings. I read this on a post from gamespot. I hope it works.
SOURCE: Samsung HLP4663W DLP 46' tv: Just
You still need to get an audio Left and right connected from the video source.And for the digital reception from the antenna source is not possible because your unit is not equipped with a digital tuner(it is NTSC or analog reception only)it needs an add on digital tuner that has an hdmi output.Newer ones now are equipped with digital tuners.
SOURCE: trying to connect PS3 to
So I had this same problem. I found that when I hooked to a 1080p TV my PS3 was working, however when I hooked to my 1080i it said Not Supported Mode. So I then hooked to the 1080p and told my PS3 to limit it's self to 1080i mode and hooked it to my Samsung TV and it worked just fine. Give that a try and it should solve the problem. Hope this helps.
