If your copier front or right cove is not attached properly then CH on standby, or CH is blinking/flashing may be your copier TD unite is not adjust or close.
On my AL-1551CS it means the right cover is not latched when CH is on steady (not flashing). If CH is flashing, the toner unit is not seated correctly.
Why it can't remove CH message
SOURCE: WHAT DOES THIS MESSAGE MEAN: CH
It is the fuser, but sometimes it is just a false code. to reset enter buttons clr, exposure, clr, exposure, the display will blank, enter 14, press prnt button, then clr several times to get out and thats it. -------- if still the same the fusser needs to be get checked and replaced.
