Question about Dewalt DW056 18 Volt Cordless Impact Driver - 1/4" Drive Hex Shank (Battery Charger and Case Not Included) - Tool Only
Best lubricant/grease for dewalt corless drills components
Im trying to get grease for my corless drill, want to lubricated it but dont know what grease to use for the cluch and gears. Is there any one iin special that it should have? Thank you.
2 Suggested Answers
Anonymous
SOURCE:
Brian Manuel
  • 354 Answers
SOURCE: I'm trying to get grease
I would use oil not grease,grease collects dirt and is a mess in the heat. use a gear oil and youll be fine
Posted on Feb 15, 2011
What is the best lubricant to use on my dewalt hammer drills please
It depends to where you want to apply your lubricant.
If you want to lubricate the chuck with the sds drill bit you simply add some cheap grease on the drill bit and the drill bit will slide easily on the chuck. On the other hand if you want to lubricate the sds drill machine then there is a special type super grease that you can buy from Dewalt in order to do so. Also since in order the super grease to be needed this means that you have used the drill a lot then also is needed to change o-rings, brushes and so on. So usually you have to ask for a service center to do it since they know how to do it properly and using the right kit.
Oct 18, 2014 | Dewalt Drills
What is the best lubricant to use on a dewalt hammer drill please
Depends what you want to lubricate.
If you want to lubricate the drill bit to move front and back a WD40 is ok and grease is better too.
Where should I grease the hilti 7c
You should not have to grease The TE-7. It is permantly lubricated. You can occasionally put a small ball of grease on the end of a drill bit before you stick in the chuck. This will keep the chuck greased.
Aug 14, 2010 | Hilti TE 7-C 120V Rotary Hammer Drill
Te70 hilti hammer drill
The TE-70 is permantly lubricated. You would only add lubricant if you took the tool apart. You can add a small amount of grease to the end of your bit occasionally before putting in the chuck. This keeps the chuck parts lubed.
Jul 09, 2010 | Hilti TE 7-C 120V Rotary Hammer Drill
Drill stuck in hammer mode
Did you try oil or other type of lubrication under the bezel? Hammer drills make a lot of dust.
Nov 13, 2017 | Dewalt 18 Volt Xrp Heavy Duty Hammer Drill...
Greasing - when & where?
www.dewaltservicenet.com
this drill has self-lubricating bearings and shouldn't need grease
Nov 25, 2008 | Dewalt DW999K 7/8" Cordless SDS Rotary...
General maintenance
These tools need very little maintenance. Make sure your chuck is tightened down, inluding the screw in the middle of it, as this can work loose over time and jam the jaws. Other than that it is just a matter of using an airline through the vents to blow any dust/debris/carbon out. The gearboxes are enclosed so need little lubrication and the motor has plain brass bearings. If the motor squeals a little when starting/stopping jsut apply some oil behind the pinion gear and on the shaft at the rear of the motor.
Oct 19, 2008 | Dewalt 18 Volt Compact Drill Kit
Dewalt DW056 18 Volt Cordless Impact Driver - 1/4" Drive Hex Shank (Battery Charger and Case Not Included) - Tool Only Logo
866 people viewed this question
Top Dewalt Drills Experts
Marvin
Marvin
Lance Guthrie
Lance Guthrie
Level 1 Expert
Spud Howell
Are you a Dewalt Drill Expert? Answer questions, earn points and help others
