Coby DP-767 7-Inch Widescreen Digital Photo Frame with MP3 Player & 2 Metal Frames Logo
Posted on Dec 29, 2009
My children gave me a digital photo frame for Christmas. I have a Nikon digital camera. I have downloaded and deleted from my camera several pictures I would like to put into my photo frame. Am I able to retrieve them from my computer to my camera chip so I can put them into my frame??
Anonymous
Level 1:
New Friend:
  • Contributor 1 Answer
  • Posted on Dec 29, 2009
Anonymous
Contributor
Level 1:
New Friend:
Answers
Questions
Helped
281
Points
If the "camera chip" you refer to is a removable SD Memory Card you need to put that into a SD Card Slot on your computer or use an USB Card Reader device. The computer will recognize the SD Card as a Disk Drive and you can use Windows Explorer to transfer the picture files to it.
3answers
Photos deleted
GT Recovery for Windows Download: www.gtrecovery.net
GT Recovery for Windows is a professional data recovery for PC and Android phones. It can restore deleted photos, videos, audios, documents from PC.
Whenever you lost important photos or deleted photos by accident, you can use it to scan and recover the photos on your phone.
I just bought a digital photo frame for my husband for christmas and i get so many pictures downloaded...then it just stops and says insufficient memory card.....i thought there was something wrong with...
I'm pretty sure this means that you have filled up the internal memory on the picture frame.
I just bought my sister a photoframe for Christmas (made by Phillips) and we got the same message. Not the most precise wording on the error message, but we tried deleting a few photos and the error went away. Then I checked the internal memory of the frame, and it is only 128M, which is not alot of photos.
I think the solution will be to buy a USB memory stick to leave in the frame. For about $10 you can get a 4G USB memory stick, which is about 32 times the space of the internal memory, at least if you have a similar model as we do.
See here: http://www.amazon.com/USB-Flash-Drives-Storage-Add-Ons/b?ie=UTF8&node=3151491
19helpful
8answers
I have nikon coolpix s10 VR. recently i deleted all my photos i now want to recover all those photos. is it possible?
I have had success with this camera recovery software called asoftech photo recovery... Download the program
http://www.asoftech.com/apr/
You have to use a card reader either on your computer or an external USB card reader. Put the card in the card reader, open the recovery program, then select the drive where files are deleted, then press "Start" and wait for it to do it's magic.
Apr 13, 2009 • Cameras
I can't erase
Follow these instructions, but before you do, please be sure you have saved your images off the disk prior to starting these steps.
  1. Press Menu/OK to display the playback menu.
  2. Press Up/Down to select FRAME or ALL FRAMES. Choose ALL FRAMES.
  3. Press the Menu/OK button again while ALL FRAMES is selected to confirm deleting all photos.
Please select FIXYA, thanks.
Dark pictures
There are several possibilities.
1) The camera store screwed up, and your photos are just fine. Have you looked at the photo files on your computer?
2) You accidentally set the camera into manual mode and with settings that don't work for the light. How do the photos look when you preview them on the camera?
3) This is the most likely problem: It sounds like you have accidentally set the "exposure compensation" value. This setting is used to help correct the exposure when shooting a scene that should be mostly white (e.g. in the snow, or bright sand at the beach) because otherwise the camera will make the scene be "medium gray". Check your user manual for instructions on how to set the exposure compensation and make sure it is set to 0.
If your photos are too dark when viewed on the computer and the preview screen, and EV is set to 0, then your camera may have a faulty light meter. If so, you need to send it in for repair under the warranty, or return it to the place of purchase as defective and see if they will exchange it for you.
21helpful
7answers
Is it possible to recover my pictures?
I have had success with this... Download the program
2answers
Upload images to SD card
I just purchased a frame and wondered the same thing. My computer has a slot for an SD card once inserted the computer shows the SD file. Then go into where you store the pictures highlight the picture one at a time in the picture file my program says copy to file click on it and shows the SD file as F file click copyit then downloads to the card. Done put SD card in frame worked perfectly.
Top Coby Photography Experts
Tony Parsons
Tony Parsons
ADMIN Andrew
ADMIN Andrew
Are you a Coby Photography Expert? Answer questions, earn points and help others
