Question about Toshiba Satellite Pro 6000 and 6100 14.1 LCD Display LQ141X1LH53 (P000316660) CD-ROM Drive
My Toshia Satellite Pro 6100 Screen Cant select 1024x768
My Toshia Satellite Pro 6100 screen works fine but the specifications says it has a 1024 x 768 screen but it has now only choice between 800x600 & 969x768 Please help me !
    New Friend:
  • 29 Answers
A little clarification... did you reformat your laptop? if your answer is yes>>> maybe some driver of your laptop are not loaded>>> to check the loaded just go to >>> my computer>> r-click then click manage>>> then click device manager>>> if you see color yellow sclamation point or question mark>>. it meaning to say some of your driver not installed>>> so you must download the compatible driver for your laptop>>> you can download driver on this site>>> www.driverguide.com....!
Posted on Dec 29, 2009
6ya staff
SOURCE:
Why dark manor game didnot support my monitor risolution
Windows XP
  1. From your desktop, right-click and select Properties.
  2. Click the Settings tab.
  3. Adjust your screen resolution to 1024 x 768 (or higher) and select OK.
  4. Try playing your game again.
Windows Vista
  1. From your desktop, right-click and select Personalize.
  2. Select Display Settings.
  3. Adjust your screen resolution to 1024 x 768 (or higher) and click Apply > OK.
Windows 7 and Windows 8
  1. From your desktop, right-click and select Screen resolution.
  2. Adjust your screen resolution to 1024 x 768 (or higher) and click OK.
  3. Try playing your game again.
Mac
  1. Open up the Apple menu.
  2. Select System Preferences.
  3. Click on the Displays icon.
  4. Select the Display tab to adjust your resolution to 1024 x 768 (or higher).
  5. Reopen your game.
    _
    Try this out it seems to work for some people, if that does not work try this out:
    Switch to Windowed Mode
    If you continue to have trouble playing your game in full screen mode, switch to windowed mode. Under the main menu of the game, select Options, and un-check Full Screen mode (or vica verse if you already have windowed mode on, switch to fullscreen)
    Thanks and I would appreciate a reply if that got fixed or not.
    Good Luck!
Apr 27, 2014 | bigfishgames.com
Can't get my Dell Precision M50 Laptop video to fill the screen at 1024 768 resolution. Video will only fill the screen when I set resolution to 1600 1200. Is there something wrong with my video card?
1024x768 is a native wide-screen resolution. more than likely your video card is fine and your notebook monitor does not support that format without shrinking the top and bottom which defeats the purpose of filling the whole screen. plug the kappy into an external widescreen monitor or TV and it will work at 1024x768.
Regards
Jun 06, 2010 | Dell Precision M50 Notebook
My toshiba satellite pro 6100 will not turn on. The battery light and power light turns green but it will not turn on.
The problem could be your display. Use the VGA port on the side of your laptop to connect it to a computer monitor, this will let you know if your system is posting or not. (If you see the Boot Screen it is posting).
May 19, 2010 | Toshiba Satellite Pro 6100 Notebook
The unit displays 'Not Optimum Mode 1280 x 1024 using vista
Ok, try another setting say 1024x768, 800x600 & see if that helps, what this means is for whatever reason "Windows" thinks that the current screen settings, aren't the best, for what is being "Run".
Feb 01, 2010 | Samsung SyncMaster 913N 19" LCD Monitor
With windows7 screen is small@1024/768 is ok if you use 1440/768 how can i use 1024/768 and get full screen 20 ' wide screen
Hello.
If you have a Wide screen monitor it can only (look good) in a Wide screen resolution such as 1440x768.
1024X768 is the lower resolution, and it is for normal screen (square) monitors, not for wide screen monitors.
You cannot get a full screen at 1024X768 resolution with a Wide Screen Monitor.
Hope that Helps.
Jan 29, 2010 | Evga N350 NVIDA 6600GT 128MB 128bit AGP8X...
The sides of the screen on my laptop are blacked out so the screen appears smaller. The mouse doesn go into the black bits either. i havent changed any settings i just switched it on and have this problem!...
Go to the control panel and select "display" when the window pops up select the "settings" tab and set the display to 1024 x 768, select apply and then OK.
Your problem should now be solved :)
Regards
Jun 27, 2009 | Toshiba Satellite Pro A200-EZ2204X...
No picture on lap top lcd
Do me a favor get a light source and hold it up to the screen if you can see your operating system your screen is shoot...
Feb 23, 2009 | Toshiba LCD Display for Satellite Pro...
Toshiba 6100(PS610E-02C60-EN) Screen
Read the product spicfication tharouly cheeak the compatbilitey and instal the drivers in the system then run the screen what ever the size you want pluge in to the system.
Jul 03, 2008 | Toshiba Computers & Internet
Computers & Internet Logo
73 people viewed this question
Top Toshiba Computers & Internet Experts
Ekse
Alun Cox
k24674
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
