Sony Bravia KDL-42V4100 42 in. LCD TV Logo
Posted on Apr 11, 2017
SONY BRAVIA KDL-42V4100 DOES NOT PLAY FLIP THRU HDMI INPUT
I have just received a flip video ultra HD. I have recorded some video. when I try to play the videos back on my sony bravia HD tv (model number KDL-42V4100) they do not play through the flip camcord
I have the HDMI cable connceted to the flip and the TV. The TV set to the correct HDMI input slot and the videos do not play. The tv indicates no signal. I presss the power button on the flip and press the play button and it does not play.
Could it be the HDMI on the TV? iS THERE ISSUE WITH SONY HDMI INPUTS?
tHE VIDEOS PLAY ON THE CAMCORD. COMPUTER AND ON THE DVD PLAYER WHEN i BURN A DVD
5 Related Answers
Anonymous
  • Posted on Sep 26, 2008
SOURCE: How do I hook up the HDMI cables to a cable box
how do i hook up hdmi cables to cable Sony KDL Bravia LCD HDTV
Anonymous
  • 210 Answers
  • Posted on Oct 01, 2009
SOURCE: sony bravia kdl-42v4100 no picture no sound
Sounds like there is a short on the power board or the power board has gone faulty.
Look on the power board to see if any of the capacitors are bulged or if there are any other components burnt out. The TV is going into protect mode because of an over current, which points to a short on the board or a component has gone short circuit.
Thanks
Anonymous
  • Posted on Feb 21, 2010
SOURCE: How to enable "Bravia Sync" on KDL-40V2500
I also have the same problem and was wondering if you ever found out the answer to this problem Peter?
Anonymous
  • Posted on Mar 21, 2010
SOURCE: hdmi port stopped working on sony bravia
I have a Sony Bravia model KDL-46s5100 that had the same problem. All HDMI ports stopped working. I don't know why this works but unplug the TV for about 30 sec, then plug it back in and hold down the power button on the tv for 10 seconds. Like I said I don't know why this works but it worked for me. Good luck.
Anonymous
  • Posted on Apr 01, 2010
SOURCE: KDL-40V5100 TV HDMI Issue
I have the same problem did you ever find a solution
tip
Aunsoft Video Converter helps you convert between various formats. It is the...
Normal 0 7.8 &#30917; 0 2 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:&#26222;&#36890;&#34920;&#26684;; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0cm 5.4pt 0cm 5.4pt; mso-para-margin:0cm; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-fareast-font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} <p><span>There is no other one than iPad can be more perfect for you to watch video on the go, the bigger iPad might be awkward for you to hold in some position, but 90-degree angle to use iPad from your lap is the position you'll ever found comfortable to watch video on iPad, bed or sofa will be also be ideal.</span><br /> <p><span>A pity that the NEW Apple iPad still can only play back H.264 MPEG4 (.mp4), mov, m4v Video files, so if you download flv video files from online video-sharing sites or have camera HD videos like AVCHD VIDEO(.M2TS, .MTS), even common Video files like AVI WMV MPEG that want to play Movie on iPad, you must need to <b><span><a href="http://www.video-to-ipad.net/guides/convert-video-to-ipad.html"><span>Convert Video to iPad</span><b> </b></a></span></b>compatible formats.</span><br /> <p><b><span>Why We Need a Video to iPad Converter?<span> </span></span></b><br /> <b><span>However, if we want to watch movies or listen music on ipad, we need use a video to ipad converter suite to help us.</span></b><b><span><a href="http://www.video-to-ipad.net/">Video to iPad Converter</a> </span></b><b><span>Suite</span></b><span> is all-in-one iPad Video Converter package for iPad, including two iPad tools: Video to iPad Converter &amp; DVD to iPad Converter, to convert DVD movies and videos to iPad supported video format. With iPad Video Converter Suite, we can easily convert all our DVD movies and videos to iPad and enjoy it on-the-go. So with this single package we can convert both DVDs and video file media to iPad video and iPad movie formats.</span><br /> <p><b><span>Preparation:</span></b><span> Download Video to iPad Converter and run the program, Click Video Converter button.</span><br /> <p><b><span>Step 1: Add Video to iPad Video Converter</span></b><span></span><br /> <p><span>Click <b>"Open file"</b> button to select and open the video file you wish to convert. Video to iPad Converter supports most of the popular video formats, so you can easily convert AVI to iPad, MKV to iPad, and even HD video formats like AVCHD M2TS MTS to iPad format.</span><br /> <p><b><span>Step 2: Select iPad preset from output format list</span></b><span></span><br /> <p><span>In the Output video section of the interface, choose the right preset for your iPad device in the <b>"Profile"</b> drop-down menu. There are many options when you're converting your videos for your iPad. Obviously, the better the quality, the larger the file size. Ultimately it's a personal decision everyone has to make on what's more important: space on your iPad or audio/video quality. Personally, I prefer to stick with the default profile because the good quality video and audio are given. You just have to pick and choose which profile you want to keep on your iPad. Play around and see which results you like best.</span><br /> <p><b><span>Step 3: Start Conversion</span></b><span></span><br /> <p><span>After all the necessary settings are ready, you can click <b>"Convert"</b> button to start convert video to iPad. As soon as the conversion is completed, you can click "Open" button to find out the generated files easily. And then sync them to you iPad, with iTunes.</span><br />
on Nov 04, 2010 • Computers & Internet
1helpful
How do I get a US Sony Bravia KDL-42V4100 to work in the UK?
I have encountered this before---there are set top boxes that will convert the NTSC to PAL and the only other concern is the line voltage being the same or not.
3answers
THE TORQUE CONVERTER DOESNT WANT TO GA ALL THE WAY IN.
I assume you have the tranny out and trying to install torque converter.Push converter in as you rotate it.It should line up with notch and lock in.
2answers
3helpful
2answers
E250 sansa media converter
http://www.megaupload.com/?d=3IPZO6Q0
Sony KDL-42V4100 has sound but no video. Input works but black screen and sound is ok
Hi there
this is not meant as a solution, but a tip if you`d like to get an answer.
You should clarify in which occasion you get either sound and no video or black screen with sound.
This is a little confusing for a repairman.
2helpful
Can not see the videos in the Flip Share window
Connect your flip video camcorder to your computer via the usb arm. you will find your video files in FLIPVIDEO(F:)->DCIM folder. Just copy your videos to your computer.
How to improve picture quality sharpness?
PICTURE QUALITY IS USUALLY A FUNTION OF IT'S SOURCE. GARBAGE IN GARBAGE OUT.
IF YOU HAVE COMCAST OR SATELLITE AND IT IS NOT HD, YOU NEED TO HAVE AN HD SIGNAL FOR THE BEST PICTURE. THE BEST INPUT IS THRU THE HDMI INPUT. IF YOUR UNIT HAS A GOOD PICTURE WITH YOUR DVD UNIT, THEN THE HAVE A SIGNAL SOURCE ISSUE.
Top Sony Televison & Video Experts
Grand Canyon Tech
Grand Canyon Tech
ZJ Limited
ZJ Limited
matt martin
matt martin
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
