For first look at the pipes that lead into the washing machine (HD vision) the water pipe must be bent or kinked or got blocked ot loose.
but if the piper are ok.then unplug the washer from main power outlet for 10 minutes then reconnect it and check out.
if still the same problem check out the drain pump if its clogged then it needs cleaning if its got loose or worn out it needs replacement.
but if the drain pump is ok.then its the fault in front control panel board.it has to be replaced.
you can get required parts from
www.repairclinic.com
or also from
www.partselect.com
This will
help. Thanks please keep
updated.please do rate the solution positively .thank you for using fixya
click on this link directly to reach the pump location
http://www.applianceaid.com/frigidaire_f...
the brand of washer mentioned in the link is different from your brand but the system is near to same in both washers so it will give you fair idea and help you.
to remove control panel board follow this instructions
FRONT LOADER, the console is removed in the following way:
1. Unplug the washer.
2. Remove the washer top panel by removing the three torx-type screws (or 7mm) where it attaches in the rear of the washer. The panel should slide back, and then lift off.
3. Remove the operator console by removing the dispenser and the scew(s) behind it. Take a putty knife and insert it under the console seam right above the door. If you push in slightly while pulling outwards the panel pops off. Use care not to pull or damage any of the wiring. You can leave the wires attached and simply lay the console across the top of the washer out of the way.
This will help. Thanks please keep updated.please do rate the solution positively .thank you for using fixya
Its a hoover HWD 120 there are no kinks, I switched off for ten minutes and switched back on. The door light flashed and as I continued to hold the start button all the other lights started falshing as well and the door light went out.
I have cleaned out the filter but there were no discenable obstructions.
1) How do I get at the pump is it throuh the pnel at the rear.
2) Same for the circuit board do I remove the rear panel top access the circuit board.
thanks.
The instructions were clear concise and easy to follow.
