Dell Inspiron 1501 Notebook Logo
Posted on Dec 30, 2009
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Wont load up properly - Dell Inspiron 1501 Notebook
Sacraty
Level 2:
  • Expert 64 Answers
  • Posted on Dec 30, 2009
Sacraty
Expert
Level 2:
Answers
64
Questions
0
Helped
15543
Points
160
Try cleaning your registry if you get the chance to get inside the operating system. go to ccleaner.com and downlaod it, install it then update. after updating it, run it. clean and also the registry. try checking your startups too if there are any un necessary files that you know that shouldnt be there. there is also an option on the ccleaner software where you can choose which starts on our system, make sure to have a look on it too.
last resort, restore factory settings is the answer.
DLG2351r model LG front load dryer wont start also says CL
It seems as though your machine's door switch is faulty as the machine will not start if this switch does not operate properly.
The reason that I suspect the door switch is because the CL error code stands for "child lock".
Check the door switch for continuity and condition, replace if faulty.
Oct 03, 2014 • LG Dryers
My chats page in meetme wont load my messages.....its just blank screen
go to settings select the app and clear all data. select app then sign in again.
Frigidaire gallery top load washer is leaking and will not wash big load
Hello msmm50 - Contact a professional so they can properly and accurately diagnose the unit for repairs. Sounds like you have a leak in the drain lines or the water valve.
11helpful
4answers
Flirtomatic is not loading properly
as above site will not load gets half way then freezes and now my phone also will not long on WHATS HAPPENING? Tried the fixes above but don't work
Mar 17, 2011 • Flirtomatic
Changed the blinker lightbulbs on my 2000 Sportster but now they wont work front or back. Help???
The turn signal cancelling unit is designed to work with a specific load on it. You must use the proper bulbs for it to work. If you installed LED bulbs, the load is different. You can get a "load equallizer" that will allow you to run the LED bulbs but make sure you get the correct one and wire it in properly. Look here. http://www.badlandsmotorcycleproducts.com/Tech-Pages/WHICH-LOAD-SHOULD-I-USE.htm
Good Luck
Steve
When playing dynasty warriors6 it wont start because it wont load the trophys and this game has none and now my NBA live 10 wont load either
There is a major issue occuring right across the board at this very moment with the PSN Network. Some consoles are not synching properly and causing problems like you describe.
For a full breakdown please see this FixYa Tip.
If the solution helps, please leave a vote for it. Many thanks.
3answers
Facebook content isn't loading properly
Facebook is best viewed in Mozilla browser, please try that
Wont load windows properly cant access recovery to recover factory settings
Hi...
You want to load your windows properly. You need a fresh copy of windows. Install the windows properly do not recover the existing windows maybe some files are missing. Make a new copy of windows.
Regards
PCmania
Grand Canyon Tech
Grand Canyon Tech
SmartAviator
SmartAviator
