Xerox Phaser 8200 Laser Printer Logo
Posted on Dec 30, 2009
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
My xerox phaser has a blank screen and no green light on the front of printer. I can hear the fan so I know it is getting power...... also when I plug the usb into my computer, my laptop reads that the printer is off-line. It does not recognize the printer. My printer has less than 10,000 copies so far. I replaced a heater bulb last year but I have never had a problem until now.
Robert Ackom Donkor
Level 1:
  • Contributor 1 Answer
  • Posted on Jul 03, 2019
Robert Ackom Donkor
Contributor
Level 1:
Answers
Questions
Helped
321
Points
Wendy, Please where did you get the heater bulbs? It seems i need some. My xerox phaser 7800 do not power on, fan and gears do not turn when you switch on only green led light on and the screen is off.
Anonymous
Level 3:
President:
  • Master 2,072 Answers
  • Posted on Dec 30, 2009
Anonymous
Master
Level 3:
President:
Answers
2072
Questions
0
Helped
1109671
Points
5835
That sounds like one of two things.
Either the ribbon cable to the screen needs reset, you have to remove 4 screws I believe it is, then unplug everything to that assembly, and re plug them back in.
If that does not repair it, then most likely the electronics module has failed. That is quite expensive to replace.
Xerox Phaser 7800 displays EEPROM ERROR
  1. Install IOT firmware.
  2. Initialize the IOT NVM.
  3. GO TO DIAGNOSTICS AND NVM
2answers
My xerox phaser 6300 control panel is blank and was working
Your control panel is bad and needs to be replaced, here is a video to show you how.
and here is the part (click here)
2answers
Xerox Phaser 8200 goes through post then hangs.
Sounds like a RAM problem. Go to the back of the machine, You will see  2 large, thumb Screws, Twist them about half a turn and remove the main board. Remove and reinsert the memory stick. If that does not fix it the main board or the electronics module has probably failed.
2helpful
Xerox Phaser 5500dn will not power up when turned
The problem turned out to be a defective IMAGE PROCESSOR BOARD.
3helpful
3answers
The display is blank
This model of printer has a known fault with the LCD panel.
Contact xerox in your country, who will arrange to have a replacement front panel sent out to you to install - eeven though it is out of warranty and at no charge
1helpful
2answers
XEROX Phaser 4510 screen blank
You need a new LCD unit. Unfortunately Xerox will charge you £350 for and Engineer, part and fix. Buy one yourself for $121 (US dollars) from http://www.sparepartswarehouse.com/Xerox,Printer,Part,802K93650.aspx
Xerox 3500 blank pages xerox 3450 display flashes
Clear all memory under maintenance will solve this
8helpful
3answers
Xerox Phaser 8550dt printer
That is a known problem with the 8500 phaser family.
Contact Xerox at 1-800-835-6100, They WILL replace it for free. It is a known problem.
I really believe that display is failing. very common problem.
Just tell them the display is blank when you call. But they are faulty. Very faulty.
Phaser 8200 will not start up
Are you getting any fault codes on the screes? A fairly long number..
Top Xerox Office Equipment & Supplies Experts
ZJ Limited
ZJ Limited
Grand Canyon Tech
Grand Canyon Tech
Are you a Xerox Office Equipment and Supply Expert? Answer questions, earn points and help others
