Sony Cyber-shot  DSC-W55 Digital Camera Logo
Posted on Jan 29, 2008
Video mode I can't get my camera to take a normal picture, it will only take a video clip - how do I switch out of video mode?
Anonymous
Level 1:
  • Contributor 23 Answers
  • Posted on Jan 30, 2008
Anonymous
Contributor
Level 1:
Answers
23
Questions
0
Helped
35818
Points
89
Its not actually taking videos. its just set on burst mode.
1. turn unit on
2. press menu
3. search and highlight mode (rec mode)
4. select normal and press the center button
5. press menu to exit then try to take a picture.
avaya ****
maimai alovera
I get (have) a black screen when I put my camera in the on position to take picture/video. I can view all pass picture/video, If I switch mode to view. when I switch the mode to take picture or video I...
Try hitting the display button(the small TV resembling icon in the bottom right of the camera). You may have accidentally pressed it while using your camera and caused it to turn off your display.
3helpful
How do i play whats on the memory card nothing plays video only audio. or what do i need to convert it
First, make sure you have it on CARD (and not DISK), and on the "playback" (and not record) mode. Next, does the camera play back other video clips normally, but just not a specific clip ?
Does the selected video clip frame (index) shown on the LCD screen have a picture ? If not, i.e. it is blank (dark), then it is likely that no video was recorded (i.e. just the audio) when you were shooting that video clip.
If there is a picture (of the video clip frame index on the LCD screen) and only audio is playing, try downloading the clip (from the SD card) to your computer, or simply try to play the video on the SD card (inserted directly into your SD card reader on your computer, or via a USB SD card reader) and see if the video clip will play normally on your computer.
How can i watch video from Samsung s1050 in my computer?
Hi, Here is the procedure on how to play the video clip on your camera. Play mode If you have turned on the camera by pressing the POWER button, you can press the PLAY MODE button once to switch to Play mode and press it again to switch to Recording mode. You can turn the power on with the play mode button. The camera is turned on in play mode. Press the play mode button again and the camera will be turned off. You can set up the PLAY mode function by using the camera buttons and LCD
monitor. Playing back a still image
1. Select the PLAY mode by pressing the play mode button.
2. The last image stored on the memory is displayed on the LCD monitor.
3. Select the recorded movie clip and press the Play & Pause button to play back.
- To pause a movie clip file while playing it back, press the play & pause button again. ac0dd93.png
- Pressing the play & pause button again will cause the movie clip file restart.
- To rewind the movie clip while it is playing, press the LEFT button. To fast forward the movie clip, press the RIGHT button.
- To stop playback of the movie clip, press the play & pause button, and then press the LEFT or RIGHT button. 0e83d9c.png
2helpful
Video playback is too fast
It sounds like you may be in "Fast Frame Rate" video mode. Turn on the camera to video mode, then press right/left to select normal 640 pixel video. (Depending on the camera model, you may or may not have to press "Func" or "Func Set" first).
A few days ago, by mistake,someone took three pictures on the video mode and now I cannot print those pictures. What can I do to print them?
All I can think of is to use some editing software on a computer and use it to capture a frame from a video clip, save that as a picture and print normally.
16helpful
2answers
Video Playback in fast mode (canon ixus 80)
Oh my, sounds like you accidentally recorded in "Time Lapse" mode (one of the specialized video features of your camera). Unfortunately, there's no way to convert the already taken video back to "Standard" video with sound, I'm sorry. However, you'll obviously need to set your camera back to standard mode for future videos. Press the "Function" button while in video mode. Then press left/right to select "Standard" video.
DSC-W55 Disrupted modes.
YOUR MODE SWITCH IS SET TO VIDEO AND WHAT YOU ARE TAKING ARE ACTUALLY SHORT VIDEO CLIPS, INSTEAD OF PICTURES! IF YOU WANT TO TAKE PHOTOGRAPHS YOU NEED TO RESET THE MODE SWITCH TO A SETTING OTHER THAN VIDEO. SOMETHING LIKE SCENERY, FLOWERS,PEOPLE, ETC. YOU SHOULD SEE THESE ON THE MODE SWITCH, YOU MAY ALSO GO ONLINE TO SONY DSC-W50 AND VIEW THE USER MANUAL AND STUDY THE DIFFERENT MODES OF PHOTOS. IF YOU STILL NEED ADDITIONAL HELP REPLY TO: ARCLIGHT1217
1helpful
CAMERA TURNS OFF WHEN IN PICTURE OR VIDEO MODE
Does the camera turn off or does the screen go black? if the screen goes black but the power lamp stays green then the screen is just turned off (power save mode), If it’s just the screen to turn on the LCD. There are 3 buttons just to the right of the screen, press the center button.
Top Sony Cameras Experts
ZJ Limited
ZJ Limited
Are you a Sony Camera Expert? Answer questions, earn points and help others
